1 starter motor is stuck in the engine?? SOLVED Wed May 15, 2024 10:13 pm
mmgee123
Hey everyone I own a 1988 k100 and it appears that my starter has went bad so i’m replacing the starter! I’ve removed the 2 bolts and the wire that leads to the starter, even opened the engine cover (drained the oil) and sprayed infinite PB Blaster, and it still won’t budge anyone know why that might be?
Edit: once the bolts were out and wire was disconnected the only thing holding it in was the o ring i sprayed some pb blaster and let it sit over night and gave it a good wiggle and it eventually loosened up and came out. good luck!
