1 Rear shock mount stud removal Mon Nov 12, 2012 2:33 am
Rickmeister
My thoughts at the moment are...get a spray can of "cold"...drill an appropriate size hole down the middle of the broken stud, spray in the hole the "cold", and at the same time use my heat gun to heat the area around the stud without damaging the seals in the FD, and with the best quality "Ezy-out", simply unscrew the broken stud.
If any of you out there have had a similar experience, I would really appreciate your thoughts on the matter.
Rick G has v.kindly given me a super hi-tensile replacement stud.
Thanks, Rickmeister.
