1 All lights dim at idle Wed Aug 21, 2024 8:18 am
fishboy316
Was reading Dai's recent post. I am going through something similar. Replaced the headset bearings. Went to pull it off the stand and happened to look at the sight window and the oil was over the window. Ok was about time for an oil change anyway. Fuel had poured in the oil. Found an injector stuck open. Pulled the injectors Cleaned them all, reinstalled injectors. Problem solved. Put her clothes back on. Was reinstalling the seat and I pushed to far tearing the rear hinge apart. Played around with that and at least got the seat to hold. Going to need a new hinge. Started her up, sounded good. I then noticed the lights dimming at idle. All lights are dimming at idle. Threw my hands up and walked away. Will be looking into it more this evening. Will test the system to see if the alternator is charging properly and go from there. She is running great aside from that.
I have to say that I have been looking at the Z900rs lately and times like these it looks really good!
Any suggestions would be great.
