Number of posts : 7963
Dai wrote:Check the timing (the position of the HES). If it's too far advanced it might spit fuel backwards, but what you say also suggests you are going to need to replace the z-tube, all three vacuum covers (cyls 1- 3), the vacuum tube (cyl 4), inlet rubbers and manifold rubbers.
If it is 85 you may have a vacuum sensor, another vacuum tube goes from No 1 around the front of the airbox, the sensor is mounted beside the fuel pressure regulator. Replace it with a cap [vacuum cover] same as 1-3.
But I am a devil and going to say replace the fuel lines because it could have been coming from a cracked line as they are all under pressure and bouncing off the air box.
Does the bike have the CA tank venting system? ........ I am not familiar with it but I have an idea the gas tank vents into the air box....possible the pipe inside the tank is set damage and too low and its acting as an 'overflow'
1971 Yamaha 125 YAS-1
