1Back to top Go down   Fuel Tank Leaking Empty Fuel Tank Leaking Mon Sep 05, 2022 8:28 pm
bmwk100rs
bmwk100rs
My fuel tank is leaking around the fuel level sensor plate. Has anyone here experienced this type of leak before and do you have a suggestion on how to fix it? TIA!
Fuel Tank Leaking Img_3118
Fuel Tank Leaking Img_3117
2Back to top Go down   Fuel Tank Leaking Empty Re: Fuel Tank Leaking Mon Sep 05, 2022 9:02 pm
bmwk100rs
bmwk100rs
The leak seems to be coming through the O-ring (part #: 62 16 1 459 608). I just ordered it.
Fuel Tank Leaking Img_3119
Fuel Tank Leaking O-ring10
3Back to top Go down   Fuel Tank Leaking Empty Re: Fuel Tank Leaking Mon Sep 05, 2022 10:53 pm
It's interesting that you ordered the correct part number using an incorrect diagram of the part. You must have traveled through a hole in the matrix. An illustration of the correct part is attached. The next challenge is likely to be getting gasoline from a diesel pump. Laughing
Fuel Tank Leaking Scree201
4Back to top Go down   Fuel Tank Leaking Empty Re: Fuel Tank Leaking Mon Sep 05, 2022 10:55 pm
That picture is of the early type you will find the correct O-ring from 86 onward. I cant recall the size but Real OEM will give you the size.
5Back to top Go down   Fuel Tank Leaking Empty Re: Fuel Tank Leaking Sat Sep 10, 2022 4:58 pm
RealOEM doesn't list the size of the O-ring that seals the fuel sender unit.  I checked the Canadian price for the original BMW part and BMW want $23.00 plus HST.  For an O-ring!! Highway robbery!
As far as I can tell, the correct size metric O-ring should be 4.5x45.  That has a cross-section of 4.5mm, OD of 54mm and ID of 45mm.  This is eye-balling it; can anyone else confirm?
6Back to top Go down   Fuel Tank Leaking Empty Re: Fuel Tank Leaking Sat Sep 10, 2022 6:38 pm
robmack wrote:As far as I can tell, the correct size metric O-ring should be 4.5x45.  That has a cross-section of 4.5mm, OD of 54mm and ID of 45mm.  This is eye-balling it; can anyone else confirm?
Euro Motoelectrics confirms.
Fuel Tank Leaking Scree204
7Back to top Go down   Fuel Tank Leaking Empty Re: Fuel Tank Leaking Sat Sep 10, 2022 7:24 pm
bmwk100rs
bmwk100rs
How much torque do you apply to the screws? Will 5 foot-pounds be sufficient?
Fuel Tank Leaking Img_3120
8Back to top Go down   Fuel Tank Leaking Empty Re: Fuel Tank Leaking Sat Sep 10, 2022 8:52 pm
There's no spec for that torque in the BMW manual. Just get them nice and tight.
9Back to top Go down   Fuel Tank Leaking Empty Re: Fuel Tank Leaking Sat Sep 10, 2022 9:51 pm
Laitch wrote:Euro Motoelectrics confirms.
Fuel Tank Leaking 212902
10Back to top Go down   Fuel Tank Leaking Empty Re: Fuel Tank Leaking Sat Sep 10, 2022 10:37 pm
FYI:  Found a good source for these O-rings on Aliexpress.  5.0mm CS instead of 4.5mm, but they are Vitron which is good if you're using E10 fuel.
Search for this title "CS 5mm OD16-100mm Green FKM Fluorine Rubber O Ring O-Ring Oil Sealing Gasket" to get to the product.  If I posted a link, it would probably be broken in a couple months.
UPDATE: Received the o-rings from Aliexpress in the mail. They fit perfectly and the slightly extra thickness helps to seal a little better than an OEM o-ring (5mm versus 4.5mm).
11Back to top Go down   Fuel Tank Leaking Empty Re: Fuel Tank Leaking Tue Aug 08, 2023 3:35 pm
taube
taube
Having the same issue as the OP
My tank is leaking from this plate, so I ordered the replacement o-ring from EuroMotoElectrics.
I also found the FKM Viton O-Rings robmack mentioned on Aliexpress, so I've ordered '55mm OD x 5mm thickness'. Yes I'm buying a redundant part, but it's very cheap, and AliExpress takes ages to ship anyway.
Restoration project: 1988 BMW K100RS
Currently riding: 2019 Honda CBR300R
12Back to top Go down   Fuel Tank Leaking Empty Re: Fuel Tank Leaking Tue Aug 08, 2023 6:10 pm
I get my o-rings at the industrial bearing shop.  Viton for about $3.  They have them in stock, no waiting.  You should find your local shop.  Good prices on bearings, too.
13Back to top Go down   Fuel Tank Leaking Empty Re: Fuel Tank Leaking Tue Aug 08, 2023 7:01 pm
IainM
IainM
I had the same leak from the fuel sensor plate which was easily fixed by cleaning the mating surfaces and replacing the O-ring. It has been fine since and this was ~ 5 years ago.
Iain
14Back to top Go down   Fuel Tank Leaking Empty Re: Fuel Tank Leaking Sun Aug 13, 2023 6:20 am
taube
taube
Alright, I replaced the o-ring and it stopped the leak from my fuel level float plate.
As Iain noted, cleaning the mating surfaces helped tremendously. My sender
unit accumulated a lot of rust... I think the old o-ring might have been fine, but it could no longer seal after being disturbed because the surface was so rough. Photo is before a WD-40 and wire brush treatment.
15Back to top Go down   Fuel Tank Leaking Empty Re: Fuel Tank Leaking Sun Aug 13, 2023 6:30 am
bad boy
bad boy
taube
looks like your K needs quite a bit of TLC
I wish you lots of success
Cheerz, David
Fuel Tank Leaking 9438-010
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
