1 '85 K100rs Thu May 18, 2023 6:05 pm
TimK100
Last fall just before I was going to put it away for the winter it stalled out on me . I pulled it off the road and tried to restart it, but no luck. I know that sometimes low voltage can cause issues with the electrical signals, so I went back later and charged it up and gave it another shot. It would crank and crank, maybe sputter a little and finally I got it going, but had to keep the engine really revving or it would stall out. I got it home and figured I would wait until spring, maybe it would sort itself out after a little rest. No such luck! After messing with it the last couple of days, this is what I know at this point: I can hear the pump kicking on for a second or two when I hit the starter. I pulled the fuel hose off the fuel rail and hit the button, some gas came pouring out. I re-connected it and pulled the fuel rail off with the injectors and gave it a shot - this only resulted in a small stream from each of the injectors. I've checked this before on a different bike and I have seen the spray that should have come out when I hit the button. So I tested the fuel pressure with a gauge this afternoon and got about 18 psi. Does this mean that the fuel pressure regulator is bad, or could there be other causes for this? I really appreciate your guys knowledge on these frustrating issues. Sincerely, Tim
