51 Re: I need help getting my new(to me)85 k100 running Fri Apr 14, 2023 2:44 am
kappy1027
What is a jab trick? I don't want my computer confused, I'm confused enough!
Go to page : 1, 2, 3
Davey, I think you're misunderstanding perhaps my explanation sucks first of all I was not trying to start the bike at all yesterday. I was only testing for spark, testing the fuel pump pressure from tank to fuel rail and testing the spray with the fuel rail out of the bike through the injectors.daveyson wrote:With just a touch of the button you can get the pump to run for two seconds without the engine cranking, that's normal, but you can't start your bike that way. Just try to start it the normal way.
All injectors get their pulsing earth from the same pin of the fuel injection control unit, and get power from the same pin of the fuel relay, so if there's a consistent difference between the old and new injectors, I'm thinking there's a wiring problem.
By the way, yesterday I swapped out the old injectors once I was having the two spray problems with number two and four of the brand new injectors that I just got from the United States not shutting off. I put in the old injectors and they sprayed equal turned on and turned off at the same time but also sprayed for 2 seconds. I'm not having any power problems from pins I don't thinkdaveyson wrote:With just a touch of the button you can get the pump to run for two seconds without the engine cranking, that's normal, but you can't start your bike that way. Just try to start it the normal way.
The common method used here to post videos is to post the video to YouTube, select YouTube's public option, then post the YouTube link here.kappy1027 wrote: I wish I could post the video. If anybody has WhatsApp and wants to send me their number I can send the video I've got the video down to 12 seconds but apparently it's the wrong type of file or two large of a file to post on here.
First of all, I can appreciate the problem of dealing with us in what is probably your second language. Considering the technical nature of our discussions you are doing a fantastic job.kappy1027 wrote:Davey, I think you're misunderstanding perhaps my explanation sucks first of all I was not trying to start the bike at all yesterday. I was only testing for spark, testing the fuel pump pressure from tank to fuel rail and testing the spray with the fuel rail out of the bike through the injectors.
When I tested the spray pattern with the new injectors All four sprayed for 2 seconds, injector number two continued to spray after the 2 seconds, and injector number four dripped about one drop a second after the other two injectors stopped they're two seconds spray.
My question is, is it normal with the jab method for the injector to spray for the entire time the fuel pump is priming? I read in the climber manual that the injectors should pulse at 1.5 to 9 milliseconds My mechanic told me that the two second spray would flood the engine it was delivering too much fuel. Why is it spraying for 2 seconds, is that normal, or is something telling it to spray for too long and flood in my engine every time I touch the button? I wish I could post the video. If anybody has WhatsApp and wants to send me their number I can send the video I've got the video down to 12 seconds but apparently it's the wrong type of file or two large of a file to post on here.
The connection did smell burnt and my control unit sits right on top of the battery and I have a top post battery that's I think taller than stock. The original box is missing but the control unit sits in or on.daveyson wrote:Why test it before confirming it's faulty? The computer can't make some injectors behave differently than the others.
Last edited by Point-Seven-five on Sat Apr 15, 2023 1:04 am; edited 1 time in total
To a circuit guy, everything looks like a circuit problem.kappy1027 wrote:The circuit guy is working on my fuel injection control module. Trying to keep me from having to buy a new one. They know not to do any tests without computer safe equipment. We'll see how it turns out.
I'm just hoping he doesn't make things worse.Point-Seven-five wrote:To a circuit guy, everything looks like a circuit problem.kappy1027 wrote:The circuit guy is working on my fuel injection control module. Trying to keep me from having to buy a new one. They know not to do any tests without computer safe equipment. We'll see how it turns out.
I am hoping he fixes your problem.
How long is the trip from Australia to Nicaragua? I would love if you guys wanted to come visit for a little bit. The weather's great, and I'm an outstanding hostdaveyson wrote:I know he helped your friend in the past and he deserves respect, but I think this time he isn't working in a logical sequence.
The job of the computer is to provide a pulsing earth to the injectors. There's a simple test to verify this, so opening the computer first just seems like a waste of time to me, I'm hoping not also a waste of money.
Even if the injectors are getting a constant earth, the problem could still be outside of the computer. If one of the earth wires to the injectors had shorted to the frame, then you would have a constant earth problem.
Are you doing anything to clean them beyond poking around in the engine control unit?kappy1027 wrote:Thanks again Davey, and ask if you guys. Hopefully, it will be running Monday or Tuesday. I'm really hoping it was just dirty injectors
The injectors were cleaned as I was reading your post. The tank looked clean and I cleaned the fuel rail and soaked it in vinegar. If I missed another post I apologize.Point-Seven-five wrote:A couple days ago in post #54 I suggested a couple simple tests that would pretty much pinpoint your problem. It appear that you are not considering them.
Am I correct to assume that I am wasting my time posting on this thread?
I'm finding it's a completely different ride than my radar 250 dirt bike that I have in country and all three of my Harleys that I have in the United States. It's going to be a very big learning curve! It's very torquey and if I don't get on the throttle slow enough my wife is not going to ride with me, which may or may not be a bad thingfishboy316 wrote:Congratulations! It's a fun ride isn't it!
It definitely is the fastest brick in Nicaragua, being the only one in Nicaragua. But you knew that! It would be great to find a parts bike, unfortunately Nicaragua doesn't let you import a vehicle over 5 years old. Before January of this year it was 10 years old or newer but when I bought a vehicle in the US to import here that was 7 years old, they changed the law. Just my luck.daveyson wrote:Good work. You have taken it from a no-go situation, in long hibernation, to the fastest brick in all of Nicaragua.
Since it's hard to get parts there, would it be worth keeping an eye out for a cheap brick to keep as a parts bike?
I'm a Freemason which is a fraternal organization worldwide and one of my brothers in Illinois invited me on a trip to Nicaragua with 15 other Masons to come and see his cigar factory and tour a couple other factory as well we were here. That was January of 2018 five of us returned for a second trip. In September of 2019 I came back out to see if I only felt safe in a group structure or if I can handle this country alone.duck wrote:How did you end up in Nicaragua? I’m just curious because I spent a month there in Siuna as a volunteer vaccinator back in 1977.
The fan seems to be running appropriately for a Brick operating in a warm climate, especially when in slow traffic, experiencing extended engine idling, or climbing steep grades. If the date of the last coolant flush and replacement is unknown, that should be undertaken soon. Regularly check the coolant level in the expansion tank gauge tube and keep it toward the MAX line.kappy1027 wrote:. . . it seems to be running hot, although the fan does come on and really blow the heat at my legs, so maybe it's just supposed to run this hot.
Doing brake fluid change and fork tube oil change today. Will tackle the radiator flush next weekend. I'd like to replace the hoses because when you squeeze them they sound a little crunchy inside. The problem is I can't get new hoses here, because as I said any auto parts I bring in have to fit in my pocket or a friend's pocket when they come.Laitch wrote:The fan seems to be running appropriately for a Brick operating in a warm climate, especially when in slow traffic, experiencing extended engine idling, or climbing steep grades. If the date of the last coolant flush and replacement is unknown, that should be undertaken soon. Regularly check the coolant level in the expansion tank gauge tube and keep it toward the MAX line.kappy1027 wrote:. . . it seems to be running hot, although the fan does come on and really blow the heat at my legs, so maybe it's just supposed to run this hot.
I'm more worried about the inside coming apart and dropping little bits into the flow of water and then into little passageways in the radiator and parts of the engine and blocking flow, then I am of exterior rupture. I was wondering if the silicone radiator hoses are recommended or frowned upon? Do they tend to collapse when hot and under suction?duck wrote:If you're worried about the radiator hoses then carry some of this or similar:
https://www.rescuetape.com/
And if you're REALLY worried then you could even pre-wrap all of the hoses with it.
Why can't you work with the NAPA auto parts store in Tegucigalpa? They have an international reach. Where do you live in relationship to there?kappy1027 wrote:The problem is I can't get new hoses here, because as I said any auto parts I bring in have to fit in my pocket or a friend's pocket when they come.
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » I need help getting my new(to me)85 k100 running
Similar topics
