Number of posts : 4462
Point-Seven-five wrote:The coolant hoses on Bricks seem to be nearly indestructible. All my bikes had original hoses and the only problem I had was when I tore a hose on my RT when I went down on an icy patch. If they don't leak, I would let sleeping dogs lie.
NEARLY is the operative word. I had one blow a hole on my 94 RS when it had less than 50K on it. And it was well-maintained when I got it. This happened about 500 miles after a coolant change where I pulled the hose instead of the temp sensor to drain it. I don't know if that was a contributing factor but I only drain it from the bottom of the water pump now. (And I always carry Rescue Tape now when touring.)
None of my other Ks have ever had hose issues though, even an 86 K75 with 130K on it.
