1 Another K100 running lean Sat Aug 29, 2020 9:51 pm
Michael Sydney
Yes, following my rich running problem back in July (it turned out to be a blocked return pipe fitting on the tank causing excessive fuel pressure) I now have a fuel starvation problem!
1983 K100, no modifications and all seemingly fine. After fueling up and 100km, including 110kph hwy cruising, it partially lost power. I stopped the motor and could see no problems, restarted and all good..... for another 20 km.
Again the bike slowed, felt like less than 1/4 throttle but cable fine. In neutral I blipped the throttle a few times and normal power returned. This continued for another 50km but throttle blipping no longer effective. Pottered home on what felt like 50cc.
Each time no rough running, no missing, still would Idle smoothly. I removed spark plugs, all show lean mixture, all 4 the same. Fuel pressure a steady 32psi.
If this had a carb I would diagnose blocked main jet! Fitting a new fuel filter has made no difference. All hoses are good and free of kinks. The tank vent works fine so not a tank vacuum.
Obviously the fuel mapping would not allow such a drop in performance regardless of temperature sensor. Can I only suspect the injection control unit as faulty? Suggestions please
Living in the past! K100 '83 and R65 '83.
