1Back to top Go down   Radiator mounting bolt Empty Radiator mounting bolt Tue Mar 28, 2023 11:45 pm
long way from home
long way from home
Hi fellow brick lovers.
the top bolt securing the radiator was well stuck and trying to undo it the captive nut on the frame decided to be free affraid !!! so after much cursing and broken drill bits the rad was also free.
Question: bolt length and thread maybe M6 or M5, so I can have the captive nut replaced (unfortunately in the surgery required to remove the captive nut and bolt nothing survived Sad )
Andrew
2Back to top Go down   Radiator mounting bolt Empty Re: Radiator mounting bolt Wed Mar 29, 2023 12:27 am
M6x40
3Back to top Go down   Radiator mounting bolt Empty Re: Radiator mounting bolt Wed Mar 29, 2023 3:59 am
long way from home
long way from home
Many thanks Mr Duck
Andrew
4Back to top Go down   Radiator mounting bolt Empty Re: Radiator mounting bolt Wed Mar 29, 2023 4:23 pm
Radiator mounting bolt Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
5Back to top Go down   Radiator mounting bolt Empty Re: Radiator mounting bolt Wed Mar 29, 2023 5:02 pm
long way from home wrote:Hi fellow brick lovers.
its just a standard 6mm captive nut often found in electronic rack systems for mounting hardware
several are used on the frame mounts
you will find some at your local it professionals spares boxes
stainless versions might last longer
good luck
6Back to top Go down   Radiator mounting bolt Empty Re: Radiator mounting bolt Wed Mar 29, 2023 7:21 pm
I haven't done any radiator installs lately but it MIGHT be possible to do it without a nut actually welded on there.
7Back to top Go down   Radiator mounting bolt Empty Re: Radiator mounting bolt Wed Mar 29, 2023 8:19 pm
long way from home
long way from home
Difficult to get to the nutty end of the bolt, hence the captive nut.
Andrew
8Back to top Go down   Radiator mounting bolt Empty Re: Radiator mounting bolt Wed Mar 29, 2023 8:30 pm
long way from home
long way from home
Probably go with a weld in cage m6 nut, zip zip with a MIG welder and it's done. Now who as a MIG welder near me?
Andrew
