1Back to top Go down   Throttle Locking Bolt Empty Throttle Locking Bolt Thu Sep 15, 2022 12:35 am
bmwk100rs
bmwk100rs
What exactly does this throttle locking bolt do? What is its purpose?  Does it regulate the idle?
Throttle Locking Bolt Lockin10
2Back to top Go down   Throttle Locking Bolt Empty Re: Throttle Locking Bolt Thu Sep 15, 2022 12:37 am
Mick67
Mick67
Cruise control....sort of.
Holds/slows the throttle mechanism return
K100RS 1984
VIN 0013414
3Back to top Go down   Throttle Locking Bolt Empty Re: Throttle Locking Bolt Thu Sep 15, 2022 1:05 am
bmwk100rs
bmwk100rs
Mick67 wrote:Cruise control....sort of.
So if it is untightened, then does the throttle mechanism returns/rolls to off faster?
4Back to top Go down   Throttle Locking Bolt Empty Re: Throttle Locking Bolt Thu Sep 15, 2022 1:05 am
When you screw it in the plastic tip is pressed against the internal part of the throttle grip creating a frictional drag that can hold the throttle so the return spring can't shut it off when you let go.
I adjust mine so that it is just tight enough to hold the throttle position at highway cruising speed.  This way the friction is not so high that it makes it tiring to control the speed in changing conditions, but I can let go of the grip and the speed will hold or very slowly drop.
5Back to top Go down   Throttle Locking Bolt Empty Re: Throttle Locking Bolt Thu Sep 15, 2022 1:06 am
No longer in production and extremely hard to find these days but the "Flip-a-lever" does the same thing much more easily.  I had one on one of my first K75s. It was a Godsend before I started installing real cruise control.
http://www.gunsmoke.com/motorcycling/r100gs/flip_a_lever/index.html
6Back to top Go down   Throttle Locking Bolt Empty Re: Throttle Locking Bolt Thu Sep 15, 2022 1:17 am
bmwk100rs
bmwk100rs
Point-Seven-five wrote:When you screw it in the plastic tip is pressed against the internal part of the throttle grip creating a frictional drag that can hold the throttle so the return spring can't shut it off when you let go.
Thank you, this explains its purpose well.
7Back to top Go down   Throttle Locking Bolt Empty Re: Throttle Locking Bolt Thu Sep 22, 2022 9:25 pm
k75RT Keith
k75RT Keith
Want one? I’ve got one PM for price.
8Back to top Go down   Throttle Locking Bolt Empty Throtle locking Screw Fri Sep 23, 2022 2:19 am
sydnorton
sydnorton
I have one for sale if needed just make sure you have the threaded hole under the throttle body of switch gear area as I have seen and also struck one of my K100's that didn't have the hole, hence I still have the screw.
post message me re have I found it yet and also the price. Cheers syd Rolling Eyes
