1Back to top Go down   New oil leak Empty New oil leak Tue May 29, 2012 11:30 am
captaink
captaink
I have now mentally prepared myself for an output seal replacement within the next 2 weeks however I spotted this -
New oil leak Imag0326
New oil leak Imag0327
Anybody know where it's coming from please?
1989 k 100rs
2Back to top Go down   New oil leak Empty Re: New oil leak Tue May 29, 2012 11:36 am
If you`re lucky, it`s the O-ring in the front end of the starter.
3Back to top Go down   New oil leak Empty Re: New oil leak Tue May 29, 2012 11:49 am
captaink
captaink
Thanks for the quick reply, I'll do it the same time as the back end is off then.
What if I'm unlucky?
1989 k 100rs
4Back to top Go down   New oil leak Empty Re: New oil leak Tue May 29, 2012 12:07 pm
ReneZ
ReneZ
Could also be the crankcase breather. Again, a very good clean and then a trip to see what happens.
Rene
BMW K100 - 1985 (0030029) Scotland New oil leak Rain
5Back to top Go down   New oil leak Empty Re: New oil leak Tue May 29, 2012 12:10 pm
captaink wrote:Thanks for the quick reply, I'll do it the same time as the back end is off then.
What I did have mind, the starter O-ring is the easiest fix when having an oil leak in this area.
But since you planning a bigger job...one stone, two birds.
Other possibilities more unlikely...gearbox breather....alternator sealing ring....but then I`ll guess you would have seen oil on the other side of the engine too. Do a good degreaser/clean to be shure.
6Back to top Go down   New oil leak Empty Re: New oil leak Mon Jun 25, 2012 5:59 am
captaink
captaink
Inge K. wrote:If you`re lucky, it`s the O-ring in the front end of the starter.
It is the O-ring ...
No sign of oil anywhere else Smile
Thanks Inge K
I am always amazed at the speedy responses from the more experienced folk here.
New oil leak 502531
1989 k 100rs
