1 Motoscope + BEP Sat Aug 15, 2020 4:46 am
NickyNicky
Hey everyone,
There are so many combinations out there that it's difficult to sort through and find relevant information for my setup. Hoping some gurus out there can help!
I've got a 1986 K100, and in installing a Motogadget Motoscope Pro V2.32. I also have a Marulabs BEP 3.0, mainly to convert the OEM speedo sensor signal to be compatible. I've also got a Motogadget Breakout Box B, as well as an M.Unit, which I will install once I get the basic functions of the scope sorted out. I've seen people run other setups, so if anyone feels very strongly about going in another direction while keeping good functionality, im all ears.
Right now I have the Scope and BEP installed, but I'm having issues with both the RPM and Speedo. There is very little info available on the BEP so I'm wondering if that's the culprit. The OEM lunchbox plugs are in the BEP, and I have the Red (power), Black (ground), Brown (ignition), White (Speedo), Yellow (RPM) wires connected to the BEP from the Motoscope.
First, the RPM is totally not working. The original lunchbox works, however the Motoscope is showing 0. I also checked the Grey/Blue wire on the lunchbox plugs and it's getting 13V DC. Any ideas what might cause this?
For the Speedo, im currently getting what seem like reasonable readouts in 1st gear, but then the speedo reads zero in second gear. What could cause this?
In the Motoscope there are a number of settings. I'm thinking this could also be culprit. I currently have them set as follows:
Circ (circumference of rear tire) = 2000 (approx for now)
ImpW (input wheel) = 6 impulses per wheel revolution
ImpE (input engine) = 1.0 (4 cyl, 4 stroke, 2 coils)
ImpF (RPM filter) = tried A, B, C, and D with no luck
Any gurus out there?
