1Back to top Go down   diagnostic plug for 16v K100 Empty diagnostic plug for 16v K100 Thu Jan 14, 2021 12:00 pm
warmshed
warmshed
I am looking for a plug to fit the 3 wire diagnostic socket on a 16v K100, I think its the same size on the K1100 too..  The socket has holes for very small pins and so far I cant seem to find one. Anyone help please? I don't believe I am the only person that has come across this problem.
Many thanks, Dave
2Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Thu Jan 14, 2021 12:19 pm
These normally have a blue blanking plug fitted. Is this what you are looking for ?
When diagnosing issues I normally use only 1 connecter, i.e. pin 1 is for Motronic, Pin 2 for ABS.
To see faults a 12v led is a good option. i.e. a led with resistor.
Lots of information on fault codes available if required.
diagnostic plug for 16v K100 Ir-log10
 ;BMW; K1200RS Red
3Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Thu Jan 14, 2021 12:27 pm
warmshed
warmshed
Thank you Ringfad, I was looking for a 3 pin plug to fit the diagnostic socket so I can just plug in my home made tester, dont like to just use 3 pins that will push into it.
Your offer a diagnostic info is very kind. I have done a bit of research and have sorted a lot of information but I may well contact you if
I can get a suitable size 3 pin plug to use.  Funny enough my blue cover is missing be nice to get one if you knoe where they are sold or what can be used in stead.
4Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Thu Jan 14, 2021 1:29 pm
The Blue blanking plug frequently goes missing but I can't find it as a part to buy.
I have a few if you are stuck
I have also check to see if any plugs are compatible, I have a few spare wiring looms and maybe some other connector is suitable.
 ;BMW; K1200RS Red
5Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Thu Jan 14, 2021 2:48 pm
warmshed
warmshed
That is very kind of you thanks.  I have been through my bits and cannot find anything that fits. Trust them to use a non standard socket.  Ill keep my fingers crossed.  regards Dave.
6Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Thu Jan 14, 2021 2:52 pm
I have been searching various ETK and various models for the part number for BMW's three pin blue plug. If someone has one, have a close squiz at it for any indication of the last seven digits of a BMW part number, please. Ta.
7Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Thu Jan 14, 2021 5:01 pm
Checked one of mine - Part no is 1459794 but can't find it listed anywhere.
Also checked a few looms to see if they have any plugs that fit the 3 pin diag. socket but unfortunately not.
The fuel/temp plug looks to be the same format but 4 pins instead of 3.
Edit - Just realised that it might be possible to put pins into the blanking plug, I will try and remove some  pins from one of the 4 pin plugs I have and report back.
 ;BMW; K1200RS Red
8Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Thu Jan 14, 2021 5:12 pm
Confirmed that part number 61 13 1 459 794  Plug Cap is in No Longer Available with no supersession status with BMWAG.
9Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Fri Jan 15, 2021 11:38 am
warmshed
warmshed
Two Wheels Better wrote:Confirmed that part number 61 13 1 459 794  Plug Cap is in No Longer Available with no supersession status with BMWAG.
Its a plug I need to use on the end of a tester so I can plug my tester in.
10Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Sat Jan 16, 2021 11:25 am
I have no idea where you will get a ready made plug but here is one option to make one.
1. Blanking Plug (with no pins) - normally with bike
diagnostic plug for 16v K100 Abs_bl10
2. Connecter off old loom 4 pin - think it is for fuel/temp gauge - loose wire in this example
diagnostic plug for 16v K100 4_pin_10
3. Tool for removing pins
diagnostic plug for 16v K100 Pin_to10
4. Insert pins into blanking plug
diagnostic plug for 16v K100 Finish10
 ;BMW; K1200RS Red
11Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Sun Jan 17, 2021 3:40 pm
warmshed
warmshed
What a genius, thank you. found a 3 pin plug like you show and have taken out the pins (checked the fit the socket) now got to find a blue blanking plug. Getting there slowly. thanks, Dave.
12Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Sun Jan 17, 2021 7:34 pm
You missed a step Simon: throw tool into the bin because it fell to pieces on the first use. Guess how I know... Evil or Very Mad I ended up buying a boxed set from a named manufacturer (Seeley? Can't remember and too lazy to go out and look).
13Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Mon Jan 18, 2021 10:49 am
Hi Dai
It is still alive at the moment, but would not be suitable for frequent use.
Must look out for a more professional set.
 ;BMW; K1200RS Red
14Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Fri Jan 22, 2021 5:50 pm
warmshed
warmshed
Ringfad wrote:The Blue blanking plug frequently goes missing but I can't find it as a part to buy.
Ringfad ~I have tried to get one but had no luck, If you do find you have a spare. I would gladly but it from you.  Regards Dave.
15Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Sat Jan 23, 2021 12:37 pm
I am checking with someone in London to see if he can track one down.
If not I can send you one.
I have not sent anything to the UK since Brexit so not sure if this is as straight forward as before.
 ;BMW; K1200RS Red
16Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Sat Jan 23, 2021 12:56 pm
warmshed
warmshed
Ringfad wrote:I am checking with someone in London to see if he can track one down.
Many thanks for you help,
According to the .Gov.uk website, only things over £39 attract vat or any other charges.  If you want more than £39 I may have to re-think  LOL.
17Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Sat Jan 30, 2021 4:58 pm
I managed to post it today when I was in N.Ireland  Smile
Dai was right the tool fell apart.
 ;BMW; K1200RS Red
18Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Sat Jan 30, 2021 6:23 pm
warmshed
warmshed
Thanks will wait for the postman. Did not use or have the removal tool, just cut up the old plugs to get the pins.
19Back to top Go down   diagnostic plug for 16v K100 Empty Re: diagnostic plug for 16v K100 Sat Jan 30, 2021 8:40 pm
Ringfad wrote:I managed to post it today when I was in N.Ireland  Smile
 diagnostic plug for 16v K100 723598  diagnostic plug for 16v K100 44271
