Go to page : 1, 2, 3 ... 11, 12, 13  Next
View previous topic View next topic Go down  Message [Page 1 of 13]
1Back to top Go down   83-84 engine cleanup  Empty 83-84 engine cleanup Sun Jan 03, 2016 8:13 pm
just arrived
a new to me donk from a local friend marky boy
the poor old thing needs a bit of tlc and some parts to complete , but will be just cleaned up to running condition
pics of before
83-84 engine cleanup  12487301_10203909503898182_833920286084052250_o
83-84 engine cleanup  20160110
83-84 engine cleanup  20160111
83-84 engine cleanup  20160112
some seals need replacement as you can see
coils are open circuit on the secondaries ...blast ...but what I expected to see ...(got a good one already ..phew )
so starting at the top
83-84 engine cleanup  12473777_10203913651841878_963523709666536380_o
inlet rubbers have also been leaking air and stuff
so the journey begins
2Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sun Jan 03, 2016 9:28 pm
Good score!
Knowing you, it'll look amazing in no time!
3Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Mon Jan 04, 2016 12:51 am
Well done Charlie.  I hope it is all cosmetic.  Cool
4Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Mon Jan 04, 2016 3:28 am
problem is now you need the rest of the bike as well......I can see a full bike rebuild coming.
5Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Mon Jan 04, 2016 7:08 am
still lots of things to do stan
instruments stuff ...now I have access to the workshop and test equipment again .......and not away on onsite jobs
but if a frame comes available ....hmmm might have to think about that .....was really looking for a k75 ...but I guess  I will have to make do I guess
its a hard life ol mate
thanks for the encouragement guys ... appreciate it a lot
6Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Thu Jan 07, 2016 5:06 pm
That's a nice little project, Chaz! I'll be cleaning out my Beenleigh shed in February so if there's anything K-related in there that'll help you get a chassis and ancillaries round that motor they're yours. Otherwise, it's good to have a spare power plant for the future.
7Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Fri Jan 15, 2016 8:12 am
hmm  a little cleanup around the clutch area
83-84 engine cleanup  12419168_10203952640496570_1610558055066036576_o
clutch disk has nearly no meat left in it ...but not too much thinning on the outside
83-84 engine cleanup  20160114
8Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sun Jan 01, 2017 7:52 am
this time of year again , with searing heat all around , but some welcome time off .
did a little work to the engine , ill let the pics tell the story , but looking good in some areas ,,,now
hmm having post issues , will update as i can
happy new year to all
83-84 engine cleanup  20161214
83-84 engine cleanup  20161215
83-84 engine cleanup  20170110
83-84 engine cleanup  20170111
83-84 engine cleanup  20170115
83-84 engine cleanup  20170113
83-84 engine cleanup  20170112
83-84 engine cleanup  20170114
just to get some degreaser , paint stripper , etch primer etc to clean up the main sump areas
not looking too bad eh ?
9Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sun Jan 15, 2017 3:36 am
Last bit of work on the engine , for the moment
still to clear coat the side covers , but basically that's it till I can get a frame - tank and a few other things
not looking too bad I guess
83-84 engine cleanup  20170116
83-84 engine cleanup  20170117
10Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sun Jan 15, 2017 6:28 am
whilst in there, did some pipes off old gerty , I had got some earlier that I swapped over when I did the head a couple of years ago now , but gerty's cleaned up just fine ,  just lots of time and noise
before
83-84 engine cleanup  20170118
after
83-84 engine cleanup  20170119
these will probably go on the old motor ...unless I can figure out a way to make them all more equal  and perhaps a collector ? huh ?            grin   !
11Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sun Jan 15, 2017 9:11 am
Don't worry about a muffler, just attach pipes and put ear plugs in.
12Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sun Jan 15, 2017 11:40 am
lol stan 83-84 engine cleanup  44271
13Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sun Jan 15, 2017 11:57 am
Wow Charlie!
You've certainly made a fantastic job of cleaning up the engine block and pipes. You obviously just can't help pushing the bar higher and higher - how on earth can us mere mortals ever reach your standards? I suspect that many, many, hours of elbow grease went into it.
Don't think you need a frame - just put the engine block with pipes attached indoors and make it the centre piece of your living room. A bit of clear glass on top and you'll have the perfect (if slightly heavy) coffee table.
83-84 engine cleanup  Uk-log10 83-84 engine cleanup  Sco-lo15
                              Paul  83-84 engine cleanup  905546712
14Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sun Jan 15, 2017 12:06 pm
Chocolate
Chocolate
Great!
I can't see the pictures.
It is just to shiny Wink
83-84 engine cleanup  Nebelkind-bamboobastic-used-sonnenbrille-dunkelbraun-used-look-9a0
15Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sat Mar 04, 2017 8:52 am
bit of travelling today ...thankfully overcast ...makes driving the tin box far easier  I guess just over 2000 klms for this week sat to sat
83-84 engine cleanup  20170310
so this is what I brought back
83-84 engine cleanup  20170311
thanks to rickg and al penykid I guess
an old 86 frame , pretty crusty after many years hanging around on shed walls   I hope its straight and not bent ....now what am I saying ...im bent.. in a nice and friendly way ..so wont matter too much
83-84 engine cleanup  20170312
still got to find lots of bits and pieces yet
lets see what we can do with this
more to come ..I hope
16Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sat Mar 04, 2017 12:23 pm
couldn't wait to try an experiment
paint stripper ,  then a brush on a drill ...with some very rough  attempts ..this might be possible
persistence and dedication will be needed I guess
83-84 engine cleanup  20170313
17Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sun Mar 05, 2017 4:42 am
sunday and a bit of work going on
the frame now clear of a lot of crud ...but the rust is all through the frame
83-84 engine cleanup  20170314
some severe cutting back is necessary in a few places ...but tricky to get at in the head area
a tad of welding needs to happen which I hadn't noticed before ...looks like someone forgot to put spacers between the frame and engine
can anyone help ? ..I cant weld  at all .but thinking a piece of metal might be required to strengthen up the joint welded across the support bridge ?
83-84 engine cleanup  20170315
I guess its coming along ok , may have to resort to some sand blasting in tricky places though
83-84 engine cleanup  20170316
18Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sun Mar 05, 2017 5:46 am
Have you considered pickling the frame in distilled white vinegar?  A day or two and all the rust is gone.  Follow up with a phosphoric rust preventing primer and paint.  Do you have POR products in OZ?
http://www.por15.com/
19Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sun Mar 05, 2017 6:01 am
no mate , haven't seen it , yet
seen many suggestions , like this one
http://www.evapo-rust.com.au/
molasses and water etc
but finding a big bin and a sump pump to keep flowing the stuff (like a shower ) is outside my budget ,,,erm at the moment
but I had forgotten about phosphoric acids stuff ...thanks for the reminder
there seems to be a few sections that have the rust throughout  the frame ...mostly could be categorised as surface rust
for me , in all the usual places .
but if I'm doing it I don't want to be painting over , and creating an issue later on
just hard yaka at the moment grinding it back with a brush wheel on a drill ...I do have a few flap sandpaper type wheels which cuts it back pretty
well .... just a bit tricky getting into some tight places
thanks for the reminder and suggestions
20Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sat Mar 11, 2017 8:19 am
accumulating a few bits and pieces
thanks to rick got a ducktail ...that needs a little work ...
the ducktail sure give the k a character that is instantly recognizable  so, for me, must be part of the build
and some other tupperware that will ..in time, be looking better than when I started ...I hope
for now just cutting back years of crud
83-84 engine cleanup  20170317
83-84 engine cleanup  20170318
83-84 engine cleanup  20170319
83-84 engine cleanup  20170320
21Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Mon Mar 13, 2017 10:28 pm
I find a propane torch and a stiff wire brush do a bang up job of removing paint.
22Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Tue Mar 14, 2017 5:12 am
thanks mate,  yep that might do the job
but more of concern is the rusty bits in tight places ...like the rear shock mount
I really want that stuff dug out properly ..
ill persist  leaving as little as possible needed to be blasted
currently looking around for quotes for someone to do the job of blasting where needed
23Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Wed Mar 15, 2017 3:34 am
If you want to brush on hose off, what about Diggers Rust and Stain cleaner. basically Oxalic acid in a bottle. Bunnings stock it, from what I've seen it is brushed on and just hoses off. Apparently cheap and organic, may be useful maybe not mate.
24Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Wed Mar 15, 2017 3:44 am
I'm not sure if the frame would fit in a sulo bin? Utube do plenty of electrolysis video's that show how to use a battery charger to remove rust. Would like to know how that goes for one of us. he he.
Sulobin full of water a couple of spoonfuls washing soda, Neg lead to frame under water and Pos lead to a piece of steel that's half in the water but the conneter is out and dry. Leave overnight switched on.
Gotta try that one day. Very Happy
25Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Wed Mar 15, 2017 3:57 am
"Gotta try that one day. 83-84 engine cleanup  Icon_biggrin"
We want photos! cheers
26Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Thu Mar 16, 2017 2:29 pm
blaKey wrote:"Gotta try that one day. 83-84 engine cleanup  Icon_biggrin"
83-84 engine cleanup  112350 83-84 engine cleanup  44271
me too, before I continue further
giggles
27Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sat Apr 08, 2017 6:23 am
well id given up doing anything to the frame ,,,whilst all the flood events of recent weeks were going on,
bloomin stuff I had cleaned off has rusted over pretty quickly , I guess that's normal for 80% humidity for the last few weeks ,
but a change is in the air now , with overnight temps this week in the teens rather than the 20s and humidity now under 50%
I got a tail section from rick ,,,in need of repairs , all cracked from some event
before and during
83-84 engine cleanup  20170325
83-84 engine cleanup  20170326
83-84 engine cleanup  20170327
83-84 engine cleanup  20170410
83-84 engine cleanup  20170411
83-84 engine cleanup  20170412
83-84 engine cleanup  20170413
the top cowl now has a triple layer of fibreglass for its front under section where the damage was most prevalent and at least overlapping 1
 layer for the internal remainder of the cowl for support ..
not bad for an old fella with little but ambition ?
28Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Fri May 12, 2017 10:38 am
just an update
too many scheduled holidays this month , after the flood events , and a big cleanup down in Lismore after their huge flood ..lost lots of valuable items
has me just painting and fixing stuff .that is cheap and rewarding to achieve
that rear section, updated ...just another coat to equalize the colour out ,to go
83-84 engine cleanup  20170510
front fender
83-84 engine cleanup  20170511
disks
83-84 engine cleanup  20170414
forks
83-84 engine cleanup  20170415
triple tree
83-84 engine cleanup  20170416
front and rear wheels , all prepped up
83-84 engine cleanup  20170417
83-84 engine cleanup  20170512
83-84 engine cleanup  20170513
just need to find a few things
like
a wiring loom
a tank (willing to get repaired )
foot pegs
switches
cables and some hydraulics
etc
think ill make some sidecovers
and refurbish a standard k100 rs type seat I have
the project continues
29Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Fri May 12, 2017 6:33 pm
Nice work Charlie - I'm looking forward to seeing her come together once you've got those additional bits sourced.
30Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sat May 13, 2017 1:15 am
charlie99 wrote:just need to find a few things
like
a wiring loom
foot pegs
switches
etc
Can't help with a loom, my spare has been butchered too much.
Definitely have a tank, a spare 1100 tank with one sidecover tag missing, straight though, painted silver with dark silver fogging (ala R90S).
Possibly some early type footpegs (with the cast weights attached)
What cables?  RS or RT length?  Possibly have something here, I'll have to dig.
'93 K1100LT
83-84 engine cleanup  K-dogs10
31Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sat May 13, 2017 1:21 am
cheers Al
I will defiantly have to get down to Sydney , some time this year
32Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sun May 14, 2017 2:23 pm
calliper works
just to keep a theme
83-84 engine cleanup  20170514
shakey hands makes it hard to fill in the lettering , best I can do for now...need more practice or a better way of doing it
83-84 engine cleanup  20170515
33Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Mon May 15, 2017 8:19 am
You will have Blakey in an anticipational sweat with those calipers.
34Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Mon May 15, 2017 8:38 am
id be really pleased to copy my efforts onto his callipers  keith ...but ill let him detail the lettering ...grin
I think I can here him salivating as well
I must get up his way and see how ?bargearse" is coming along eh ??!
cheers mate !
35Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sun May 21, 2017 7:32 am
just starting on the exterior finish of the rs fairing
and some of the hardware that fits behind it
thanks to the blokes in "the crew", I got some internal metalwork , though rusty as hell
just working it back to metal
83-84 engine cleanup  20170517
83-84 engine cleanup  20170518
I'm considering building a bit more around these pieces ...as the rs typically doent have pockets ...so handy for so many things ...but don't feel the need for a tank bag to carry small items
the fairing itself has had a couple of "Charlie" fiberglass fixes  from slight factures at important locations  both left and right hand sides
83-84 engine cleanup  20150510
83-84 engine cleanup  20150511
83-84 engine cleanup  20170519
the outside is starting to look the goods with some, at last, nice lines . a few divots to fill with putty  but getting there
83-84 engine cleanup  20170520
83-84 engine cleanup  20170522
83-84 engine cleanup  20170523
I think I'm going to make a bottom plate to help this issue
36Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sun May 21, 2017 10:21 am
Charlie, you have too much time, enthusiasm and resources. It makes me feel that I am too lazy. Keep at it.
37Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Sun May 21, 2017 1:58 pm
Nice job Charlie. I will send you my bikes or a complete Restoration. mech
83-84 engine cleanup  Frog1583-84 engine cleanup  Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
38Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Thu May 25, 2017 9:21 am
I understand these fairings get written off when damaged and to many it was declared they wrote it off due to the Tupperware, But! I really didn't know they had that much sheet metal in the nose. Where does it go? is it just a heat shield? Outside of that you're doing a great job mate.
39Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Thu May 25, 2017 11:01 am
All will become clear  as it progresses mate
40Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Thu May 25, 2017 4:10 pm
Charlie try using a paint pen to do the lettering, It's a lot more controllable.
41Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Fri May 26, 2017 4:47 am
yes agree martin , good tip !
will be going over it ,  a bit later
42Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Fri May 26, 2017 2:25 pm
Just an update
43Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Fri May 26, 2017 2:45 pm
83-84 engine cleanup  20170524
44Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Fri May 26, 2017 6:09 pm
Nice to see I am not the only one who can't seem to avoid those multiple images.
45Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Fri May 26, 2017 9:37 pm
Bloody hell Charlie....7 bikes... one for  each day.
46Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Mon May 29, 2017 4:45 am
bit more over the weekend
fitting mirror stuff
83-84 engine cleanup  20170525
83-84 engine cleanup  20170526
and cleaning up a set of throttle bodies ....which were quite grubby
83-84 engine cleanup  20170527
83-84 engine cleanup  20170528
screws to be replaced ...later for something shiny perhaps
83-84 engine cleanup  20170529
47Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Tue Jun 06, 2017 4:34 am
a few parts arrived , thanks to mark
now to clean them up
the seat mountings look to be off an old 84-85 model I guess ...but to modify to suit the 86 and later seat
83-84 engine cleanup  20170610
48Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Tue Jun 06, 2017 5:23 am
Put a few coats of clear on the wheelie bin and send it to the art gallery, they're always after something original.
49Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Tue Jun 06, 2017 6:37 am
83-84 engine cleanup  44271 83-84 engine cleanup  44271 83-84 engine cleanup  44271
yep its been through a few shades of bmw colours rick ...!  and some others ...
the neighbours comment every now and then ...grin
50Back to top Go down   83-84 engine cleanup  Empty Re: 83-84 engine cleanup Tue Jun 06, 2017 6:57 am
Bin there, done that.
View previous topic View next topic Back to top  Message [Page 1 of 13]
