1Back to top Go down   K100 shim removal Empty K100 shim removal Sat Nov 14, 2020 5:51 pm
allemande
allemande
Hello all,
I own two high mileage 1985 K100 (RS and RT), amongst other bikes. I'm in the process of checking valve clearances. All valves on both bikes are tight and need adjustment. I'd like to remove all shims and then see if any of the shims can be swapped to a new location, before ordering extra shims? Or would I cause damage to the valves by rotating the camshaft with a wrench without shims in place? What about having shims re-machined by a professional machine shop? Better to buy new?
Thanks!
1988 BMW K100RS (ABS); 2002 BMW R1150RT (Evo ABS)
http://www.recordingstudio330.com
2Back to top Go down   K100 shim removal Empty Re: K100 shim removal Sat Nov 14, 2020 5:59 pm
Why not systematically remove, record and replace each shim in sequence, noting in a chart the printed shim thickness as you progress through all 8 shims?  Then, measure the gaps, do your math and that will provide a final strategy to swap shims where possible and replace those that cannot be swapped.  Record your numbers in this chart:  http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/4valves/4valves.htm
The surface of the shims are hardened and machining them will compromise the hardening, causing premature degradation.  Better to shop new.
3Back to top Go down   K100 shim removal Empty shim replacement Sat Nov 14, 2020 6:09 pm
allemande
allemande
Thanks for your reply. Sure, you could do that but that doesn't answer my question... Very Happy I was curious about whether it is ok to remove a shim and then rotate the camshaft.
4Back to top Go down   K100 shim removal Empty Re: K100 shim removal Sat Nov 14, 2020 6:16 pm
I can't believe that it is a good idea to do that.  The cams might contact the bucket edges and potentially damage them if so.  I'm sure others will pipe up and possibly counter that opinion.
BTW, you can use Suzuki shims in these engines. Suzuki shims might be more readily available.
5Back to top Go down   K100 shim removal Empty Re: K100 shim removal Sat Nov 14, 2020 7:37 pm
robmack wrote:I can't believe that it is a good idea to do that.  The cams might contact the bucket edges and potentially damage them if so.  I'm sure others will pipe up and possibly counter that opinion.
Don't rotate the engine without the shims it will cause damage. Kawasaki shims also fit but beware of the Yamaha shims they have a small champfer which I believe will cause premature wear on the cams. Always measure the shims at the centre using a micrometer because vernier calipers will give a false reading on worn shims.
6Back to top Go down   K100 shim removal Empty Shim removal Sat Nov 14, 2020 8:19 pm
allemande
allemande
Thanks for the replies. I just wanted to make sure that it was a big no-no....
7Back to top Go down   K100 shim removal Empty Re: K100 shim removal Sun Nov 15, 2020 12:42 am
