1 Fitting a K1100 front end to a K100 Sat May 09, 2020 3:47 am
redrockmania
The Front ABS sensor is bolted into a hole on the lower fork leg. Got the 2 holding bolts out Ok but the sensor would not respond to heat, lubrication or hammering. I have decided not to to fit ABS to my K100 so sacrificed the sensor by drilling out the centre of the sensor then belting it with a drift and hammer. It eventually came out. Again, an electrical/chemical corrosion had taken place effectively welding the sensor in place to defy removal.
I guess the lesson is when you are reassembling a front end, carefully clean any lugs and holes and apply a quality anti-corrosion/anti seize - it can save a lot of future trouble.
