1 K1100 front end on a K100 - straight bolt on? Wed Sep 04, 2013 12:24 am
floyd
Will a K1100 front end (triple trees, forks, brakes, wheel, axle, steering stem) fit straight onto a K100?
Yes. 305mm floating on the K1100 versus 280mm fixed on the K100Are the K1100 standard calipers of the floating variety?
The K75 ProjecktI've also read (maybe in a post by you Rick) that GSX1400/Hayabusa front ends are a simple conversion.
No. The triple tree spacing is different so you have to solve that problem. Bearings are different as well. I don't know how you'd adapt the GSXR throttle assembly to the K100 throttle body design. That would be a challenge. As would finding all the proper switches on the right hand cluster (turn signal, emergency off, start button and light switch).Is it just a matter of using the K100 head stem pressed into the lower GSX triple clamp? and using the GSX master cylinder as well?
K100-forum.com » Technical, repair and troubleshooting » Frame, fairing and wheels » K1100 front end on a K100 - straight bolt on?
Similar topics
