toddyBMW
toddyBMW
Hi, I have a 1985 K100RS, and noticed that under the fuel tank there are 3 plugs/ sockets that do not connect to anything. They obviously do not plug into each other.
Image here, I have circled the plugs/ sockets in question  https://ibb.co/9hDzXMW
I believe the bike ran OK until it developed a fuel pump voltage supply issue.
Maybe these are for different variants of the K100 ? Or am I missing something ?
2Back to top Go down   plugs sockets under tank, where do they go. Empty No go Fri 01 May 2020, 16:38
daveyson
daveyson
Since it ran without the plugs connected, it's not a problem. The bottom one for example is the connection for additional instruments (eg. fuel level gauge) Can't see the colours for the others,  but you will find it on the wiring diagrams available on this forum at portal/k100 forum tech page/electrical/electrical diagrams.
 ~120,000 km
kioolt
kioolt
The socket for the heated grips is under the tank.
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
volador
volador
Top most connector- Two pin round terminals (brown, green, black) = heated grips
Three pin flat terminals (brown, green, ?) = hazard switch
Three pin round terminals (brown, blue, green/black)= connector for additional instruments Temp gauge or fuel gauge
Careful with the fuel level sender= fuel pump power
No longer available
plugs sockets under tank, where do they go. 5332-100320203828-28381061
plugs sockets under tank, where do they go. 5332-100320203821-2837994
toddyBMW
toddyBMW
Thanks for the replies, puts my mind at ease. I checked the bike again and sure enough the hazards and grip heaters do not work. Other electrics seem OK. Will move on to the underlying problem.
Just out of curiosity how did you end up with a K Bike in Moresby?  How far can you go, for instance Rogers/Lae Lae, Sogeri or Rigo?
My first bike was a Suzuki TC100 which I learnt to ride around there as I lived in Korobosea then Hohola.
toddyBMW
toddyBMW
Most bikes here are brought in from Australia and stay here. Guys import themselves, this K was previously owned by an Australian who has since gone finish, also had a K75 will post a picture of the other BMWs soon.
I'm in Port Moresby, we have a club that goes out on a Sunday. Favorite ride is Sogeri, also Kwikila, off Maggi Highway. Sometimes Lealea. Hiritano highway is pretty impassible nowadays without a dirt bike, will not take my F800GS. That used to be a good run
