1 K100 Sparks in the tank ! Fri May 01, 2020 8:50 am
toddyBMW
The fuel pump plastic mounting bracket has broken inside the tank. I noticed that there was sparking between the metal pump body and the inside of the tank Could easily have turned into a catastrophic situation.
Took the pump out (the pump actually works OK) and it turns out the body/case of the pump is at 12 volts, zero ohms from 12 volt supply.
I can not imagine this is normal ?
