1Back to top Go down   K100 Thermostat hose substitution??? Empty K100 Thermostat hose substitution??? Sat Apr 18, 2020 5:22 am
StandardK
StandardK
Anyone know of a substitute for the thermostat hose that runs across the back of the radiator?
Regards
Dan
StandardK
StandardK
Thanks Duck, I have seen those ones, I was more wondering if there was a car hose someone knew of that matched the size & ID
Regards
Dan
hmm
nothing iv seen around dan
although a rummage around your local supercheap might give a result ???
Dan the OEM hoses were nearly indestructible very rarely do they cause trouble. What's wrong with yours?
StandardK
StandardK
Might give Repco/Supercrap a try- I don’t hold hopes high tho....it’s about a $50-odd hose from Munich What a Face
Tiniest pinhole leak you’ve ever seen. Just enough to weep barely a drip over a week....very annoying!
On a plus note, all the body parts are currently awaiting fitting in a new flashy coat of Madison cheers
Regards
Dan
You could always try Chris and see if he is in a generous mood. It does happen occasionally.
8Back to top Go down   K100 Thermostat hose substitution??? Empty K100 Thermostat hose substitution?? Sat Apr 18, 2020 10:18 pm
Hi Dan,
I have a hose here if you want it. It is about 280mm long with a right angle bend at one end. The bendy bit is about 50mm long.
Just pm me and I'll be happy to post it up. It is the OEM hose but looks in good nick.
Tom
StandardK
StandardK
Tom FKR wrote:Hi Dan,
Tom
Thanks Tom, very kind of you - I’ll give you a buzz if I have no luck tomorrow.....bloody hoses....   Evil or Very Mad
Regards
Dan
StandardK
StandardK
All good thanks gents, thank you for the suggestions/offers - I managed to pick up a good hose locally cheers
Regards
Dan
