1Back to top Go down   Rear brake hose routing options? Empty Rear brake hose routing options? Wed Feb 05, 2020 12:39 pm
schrocketeer
schrocketeer
For a 1985 K100RT, the flexible brake line coming out of the rear master cylinder has a new part replacement that is 95mm (3.74 inches) longer than the original. Would you please help me with routing options?
Original part number:34 32 1 450 555    BRAKE HOSE - L=275MM (to 12/91)
Replacement part number:34 32 2 310 962    BRAKE HOSE - L=370MM (from 12/91)
This is from Max's page: http://shop.maxbmw.com/fiche/DiagramsMain.aspx?vid=51754&rnd=07242017
As I was rebuilding the rear master cylinder, I thought I had the wrong part number, since the replacement was so much longer than the original. My old one wasn't leaking. I just thought it would be smart to replace a 34 year old brake line. :-o
I'm concerned about ground clearance for this extra length.
Rear brake hose routing options? Modify_inline
Ken
85 K100RT
91 XR250
97 XR100
70 CT70
06 YFM400
Past Bikes:
95 VLX600
86 TRX250
02 GZ250
83 Z50R
78 ATC90
86 XR250
79 XR500
72 AT1
75 YZ360
78 DT400
75 DT125
73 Trail 70
Dad's bikes I rode in high school
69 CL175K3 Scrambler
71 R5-B (RD350 predecessor)
2Back to top Go down   Rear brake hose routing options? Empty Re: Rear brake hose routing options? Wed Feb 05, 2020 2:32 pm
Not having an '85 K100RT to look at, I wonder if the longer hose replaces the two piece line of the pre12/91 configuration.
3Back to top Go down   Rear brake hose routing options? Empty Re: Rear brake hose routing options? Wed Feb 05, 2020 2:39 pm
schrocketeer
schrocketeer
It still has a two piece assembly: front piece flexible hose, back piece metal tube.
Ken
85 K100RT
91 XR250
97 XR100
70 CT70
06 YFM400
Past Bikes:
95 VLX600
86 TRX250
02 GZ250
83 Z50R
78 ATC90
86 XR250
79 XR500
72 AT1
75 YZ360
78 DT400
75 DT125
73 Trail 70
4Back to top Go down   Rear brake hose routing options? Empty Re: Rear brake hose routing options? Wed Feb 05, 2020 4:33 pm
Maybe you're supposed to replace both parts of the old brake line with the new hose.
5Back to top Go down   Rear brake hose routing options? Empty Re: Rear brake hose routing options? Wed Feb 05, 2020 7:12 pm
Mick67
Mick67
For what its worth, when I replaced mine (84RS), the new hose in kit went straight into the caliper and removed the metal pipe as well.
Cheers Mick
K100RS 1984
VIN 0013414
6Back to top Go down   Rear brake hose routing options? Empty Re: Rear brake hose routing options? Wed Feb 05, 2020 8:02 pm
Mick67 wrote:For what its worth, when I replaced mine (84RS), the new hose in kit went straight into the caliper and removed the metal pipe as well.
Cheers Mick
What about the grommet that goes around the metal/rubber hose connector and fits into the swing arm?
Rear brake hose routing options? 2F9cCBI
7Back to top Go down   Rear brake hose routing options? Empty Re: Rear brake hose routing options? Wed Feb 05, 2020 8:53 pm
Mick67
Mick67
Ran the brake line through the grommet. Looks like about 10cm extra length on line with pipe removed..
Rear brake hose routing options? 20200210
Rear brake hose routing options? 20200211
I know I need a new grommet.
K100RS 1984
VIN 0013414
8Back to top Go down   Rear brake hose routing options? Empty Re: Rear brake hose routing options? Wed Feb 05, 2020 9:34 pm
Interesting. Thanks for the pics.
