1Back to top Go down   TE connector required Empty TE connector required Wed Nov 20, 2019 6:25 am
td5
td5
I have a K1300R and under the battery compartment there is a 3 wire TE connector ( female) I would like to wire in my TomTom Drive 550 (ridiculously thin wires) so I can have switched power to the unit. Any ideas where I can get the male connecter part reasonably priced?
TE connector required Img_0612
TE connector required Img_0611I
TE connector required K_engi10
1988 / K100RS
2013 / R1200GS
2015 / K1300R
2002 / R1100S BCR
2Back to top Go down   TE connector required Empty Re: TE connector required Wed Nov 20, 2019 1:22 pm
You could change the whole connector with a waterproof three pin connector from an electronics store.
3Back to top Go down   TE connector required Empty Re: TE connector required Wed Nov 20, 2019 5:53 pm
That would be my way of doing it. Probably cheaper than buying a TE plug too.
4Back to top Go down   TE connector required Empty Re: TE connector required Wed Nov 20, 2019 6:33 pm
I replaced the troublesome OEM 4 pin tank connector with one from Jaycar. Three pin is also available for $10.95 Au. https://www.jaycar.com.au/automotive-waterproof-plug-socket-set-3-way/p/PP2112
TE connector required Three_10
6Back to top Go down   TE connector required Empty Re: TE connector required Fri Jan 31, 2020 2:32 pm
I'm moving this post from where it was posted in Member's Intro to electrical troubleshooting.
That lead is likely the BMW Nav 5 GPS connector - BMW dealers sell a two wire connector, that plugs straight into that three pin connector, with pos & neg and a length of yellow wire which you can use to connect to your Tom Tom. It's not inexpensive, however, so the aforementioned options might suit beter.
Last edited by Two Wheels Better on Fri Jan 31, 2020 2:39 pm; edited 1 time in total
7Back to top Go down   TE connector required Empty Re: TE connector required Fri Jan 31, 2020 2:37 pm
I'd just use Posi-Taps.
8Back to top Go down   TE connector required Empty Re: TE connector required Fri Jan 31, 2020 2:49 pm
Also:  For accessory devices with very thin wires like your TomTom I always strip those carefully and then solder them to thicker wires and cover the soldered section with a layer or two of heat shrink tubing.
