Number of posts : 7955
Lets say that the O ring is best to happen in November than in April.
Unfortunately it means that you have to get the clutch off the engine, as in split the engine.
Its probably the biggest job on a K but having done it, if you do it right, you will be inspecting every part that could cause a problem down the road. At £250 though you are still winning. Its not a diy job for a lot of us, but if you have a workshop and reasonable skills its achievable. In doing it you will be eliminating all the potential downsides of the K and would have little problem selling it on to anyone on the forum with a history like that. Parts are not a big issue, you will be able to source them all easily.
My friend here is an ex BMW guy and he figures about 5 workshop hours to do it. That's in a modern workshop environment. You would need a bit longer doing it at home because you won't have all the parts on a shelf and will buy as you need them. You get a chance to inspect all of the splines and drive shaft, engine output splines, clutch. I know 88KE did this just before we went to France.
There are a lot of threads here on it. There are also threads on oil resistant clutch options, as in don't bother with the seal and leave it all until it gets on the clutch then change the clutch for the oil resistant one and just leave the seal alone. In the meantime park on main stand and keep it drained and it could be quite a while before it becomes an issue.
1971 Yamaha 125 YAS-1
