51 Re: Oil leak/timing cover Mon Nov 25, 2019 12:07 pm
brickrider2
Much appreciated info, guys! I'm off in search of the spring-type seal today. That will be a known item, and I'm less likely to need three of 'em! Thanks.
Go to page : 1, 2
Did you use the old-style OEM seal or an aftermarket equivalent?brickrider2 wrote:I decided against using the newer Teflon seal, reasoning that I'd be better served with what I'm accustomed to.
Go to page : 1, 2
Similar topics
