1 Will I need to replace the seal if removing the timing cover? Thu Dec 20, 2012 2:19 am
Hi, I need to remove the cover over the timing chain on a K75 engine. There is a seal on the cover that seals the hall effect sensor shaft. Will it be necessary for me to unconditionally replace that seal when replacing the cover? Or is it reusable as is?
