1 Fitting of shaft seal in timing chain cover Sat May 05, 2012 10:30 am
ReneZ
Team, doing some work on the bike and am renewing the seal of the timing chain cover. This seal has changed and from the original seal now a seal with a PTFE lip is to be fitted. As this fitting will not be easy (against the lip) I did a bit of a search. Moto-Bins says to soak the seal in oil for two hours. The German Flyingbrick.de site is very clear that it is to be fitted dry and manufacturers info from Reinz that clearly advises a dry fit. SKF states it can be both, but if wet should be with specified grease. One wonders..... :pale:
Anyway, what did you do? Comments appreciated, meantime I'll try to get a response from Moto-Bins.
Greetings from
Rene
BMW K100 - 1985 (0030029) Scotland
