Number of posts : 7963
brickrider2 wrote:The exact source of the oil leak is not clear at this time. However, I am certain it is not the coolant/oil pump drain hole. It has to be further up on the engine. The leaking oil is able to run down the inside surface of the left side fairing. I had a brief look before I washed the bugs off this morning. I'll need to remove some fairing bits for a better look, but at this point I think the oil is escaping at the seam of the head and block. I'd removed the cams to set the valves when I first received the bike, so there is a chance a retorque of the head will cure this. I'm struggling to feel optimistic though. When I first pulled the fairing off for that work I found oil on the fairing exactly where is it running down now. This leak had been there for some time, with the previous owner. He forgot to mention this when we were negotiating.
Seam of head and block is a long way in......is it possible its coming from the seam of the cam cover and the head? My K100 was weeping a little there when I used fully synthetic oil, stopped when I went back to semi synthetic. Has it only happened after the valve clearance work you did or was it there before it? I know you are saying it was there but.....I found it took 2 attempts to get these covers back on oil tight, one time the right hand cover took me 3 attempts.
1971 Yamaha 125 YAS-1
