1Back to top Go down   clutch spline engine support? Empty clutch spline engine support? Fri Aug 23, 2019 12:38 am
schrocketeer
schrocketeer
Would someone please (re-)post the plans for the wooden engine support to use while doing a clutch spline job?
I don't happen to have a "BMW hoist 00 1 510" like the service manual calls out.
Since I've got a Harbor Freight motorcycle lift, I can't easily get a motorcycle jack underneath the oil pan.
Ken
85 K100RT
91 XR250
97 XR100
70 CT70
06 YFM400
Past Bikes:
95 VLX600
86 TRX250
02 GZ250
83 Z50R
78 ATC90
86 XR250
79 XR500
72 AT1
75 YZ360
78 DT400
75 DT125
73 Trail 70
Dad's bikes I rode in high school
69 CL175K3 Scrambler
71 R5-B (RD350 predecessor)
2Back to top Go down   clutch spline engine support? Empty Re: clutch spline engine support? Fri Aug 23, 2019 1:32 am
I have a stack of 2x8's about 10 inches long that I put under the engine.  With the rear mudguard removed I put a sawhorse under the rear loop after the swing arm and final drive are removed.  That supports the bike well enough to slide the transmission back on a couple 4 or 5 inch 8mm bolts.  That is enough to get at the clutch splines to do a lube.
If you want to pull the transmission completely, pull it almost all the way back on the bolts, and put another pile of blocks under it before wiggling it free of the engine.  If I recall correctly, removing the stands from the transmission makes it a bit easier to handle.
3Back to top Go down   clutch spline engine support? Empty Re: clutch spline engine support? Sat Aug 24, 2019 2:56 pm
glennpm
glennpm
I use a Set of sawhorses. I set one side, slide the 2X4 through the frame and then set the other sawhorse on the other side. These sawhorses grip the 2X4 and are not permanently nailed to the 2X4.
Glenn
clutch spline engine support? Dcp_2410
4Back to top Go down   clutch spline engine support? Empty Re: clutch spline engine support? Sat Aug 24, 2019 4:44 pm
glennpm wrote:I use a Set of sawhorses. I set one side, slide the 2X4 through the frame and then set the other sawhorse on the other side. These sawhorses grip the 2X4 and are not permanently nailed to the 2X4.
Glenn
But a sawhorse won't work if you're using a lift because the lift is too narrow.
I used to use a 2x4 sawhorse.  Worked fine but now I use a metal sawhorse. Never had issues with the 2x4 sawhorse but the metal one seems a bit more stable.
clutch spline engine support? XtG0Co2
clutch spline engine support? 38sddy
clutch spline engine support? Ute6cAa
5Back to top Go down   clutch spline engine support? Empty Re: clutch spline engine support? Sat Aug 24, 2019 11:03 pm
I use two sawhorses and two pieces of 2x4 stacked. It gives you more room than one sawhorse and appears more stable.
6Back to top Go down   clutch spline engine support? Empty Re: clutch spline engine support? Sun Aug 25, 2019 12:13 am
Woodie
Woodie
Glenn
And Molson Golden too it would seem.  Haven't seen a case of that in years....
clutch spline engine support? Logo2111
1985 K100RT  52667
1990 K75RT 6018570 (project)
7Back to top Go down   clutch spline engine support? Empty Re: clutch spline engine support? Sun Aug 25, 2019 12:26 am
MartinW wrote:I use two sawhorses and two pieces of 2x4 stacked. It gives you more room than one sawhorse and appears more stable.
No pic. Your post doesn't count. Laughing
8Back to top Go down   clutch spline engine support? Empty Re: clutch spline engine support? Sun Aug 25, 2019 12:54 am
Give me a minute while I pull my Brick apart and recreate the scene.
9Back to top Go down   clutch spline engine support? Empty Re: clutch spline engine support? Sun Aug 25, 2019 1:02 am
I'm having trouble reconciling the number of stacked pieces of 2x4 with the number of sawhorses. I'm going to Khan Academy for some help.
10Back to top Go down   clutch spline engine support? Empty Re: clutch spline engine support? Sun Aug 25, 2019 2:27 pm
glennpm
glennpm
"And Molson Golden too it would seem.  Haven't seen a case of that in years...."
Yeah I noticed that yesterday when I posted!! Picture was from March 2004, first spline lube I did on the bike. Great beer BTW ;-)
Glenn
