1 Clutch spline lube question? Mon May 21, 2018 9:06 pm
dakelvinator
Hi I am planning a main rear seal replacement this weekend with spline lube and clutch friction plate replacement. I just have a few questions if anyone can help answer i would be grateful☺
1) should i submerge the new seal in oil before placement for a period of time?
2) should i put lube on the back plate/flywheel splines?
3) what is the torque procedure for the main nut? i.e tighten to a certain torque then loosen than tighten to a different/final torque setting?
thanks in advance k.
