1Back to top Go down   1987 BOGE rear shock Empty 1987 BOGE rear shock Mon Jan 07, 2019 12:55 pm
Quzzy
Quzzy
Is there any adjustment on this prehistoric device?
2Back to top Go down   1987 BOGE rear shock Empty Re: 1987 BOGE rear shock Mon Jan 07, 2019 4:46 pm
Not sure, but if they can be adjusted, it may require a stone and antler tool.
3Back to top Go down   1987 BOGE rear shock Empty Re: 1987 BOGE rear shock Mon Jan 07, 2019 6:25 pm
Quzzy wrote:Is there any adjustment on this prehistoric device?
Include a picture so we can see for ourselves. Boge and Koni shocks of that era had at least a spring preload adjustment, and if you were lucky, damping adjustment, too.
"Politics is the entertainment division of the military industrial complex."
- Frank Zappa
4Back to top Go down   1987 BOGE rear shock Empty Re: 1987 BOGE rear shock Tue Jan 08, 2019 2:03 pm
Quzzy
Quzzy
1987 BOGE rear shock Z
5Back to top Go down   1987 BOGE rear shock Empty Re: 1987 BOGE rear shock Tue Jan 08, 2019 2:38 pm
That's a Nivomat, and a self-adjusting airbag of sorts. If it's flat it's cactus. There are still whizzes out there with the skills and knowledge. A quick ask of the Google Gods revealed several claiming insight.
- Frank Zappa
6Back to top Go down   1987 BOGE rear shock Empty Re: 1987 BOGE rear shock Tue Jan 08, 2019 2:45 pm
Quzzy
Quzzy
Its working fine, I just imagined a BM shock would have adjustment and was surprised it didnt have any apparent means. Airbag makes sense, thanks
7Back to top Go down   1987 BOGE rear shock Empty Re: 1987 BOGE rear shock Tue Jan 08, 2019 2:57 pm
Quzzy
Quzzy
Read up on it now, looks like they were highly thought of 30 yrs ago when it was new, time for a replacement in the coming months methinks
8Back to top Go down   1987 BOGE rear shock Empty Re: 1987 BOGE rear shock Tue Jan 08, 2019 5:23 pm
There are several good choices out there. Lotsa folk here use Ram from UK, successfully, as well as Hagon. There's also Thai-built YSS, the very budget oriented Ikon, a Koni knock-off, and my current favourite is the Progressive Suspension 465 series. If you want to throw money at it try Wilbers or Ohlins.
- Frank Zappa
