1 Head Scratching Wed Dec 19, 2018 2:49 am
GF Wollongong
Bike gave me the bird this arvo
Was not used for some time.
Battery kaput and replaced. Last week when jump started with this (now replaced) battery in the bike, it ran fine for a while and revved out and then cut out. Am imagining that I heard a click or a pop....
This arvo...
New battery (Yuasa)... 12.48V when off, 11.38V whilst cranking
Fuel good (98 Octane and new)
Fuel pump could be heard when starter briefly pressed twice to pressurise fuel lines.
ECU believed to be good (though clip would release if pulled). Replaced with known working unit
Starter cranks ... occasionally will disengage and spin. At other times cranks continuously
Spark (blue) visible at #1 plug when grounded on engine.
Fed some fuel into cylinder and then cranked. No ignition.
Walked away...beer on offer.
Will check fuel pump again tomorrow.
Battery is large and comes very close the to bottom of ECU housing. Any chance of shorting here?
Given previous battery issues, I connected a spare (battery to earth - new improved thicker gauge) wire to the positive terminal and this comes out of the LHS of the bike to facilitate jump starting. It does not contact the frame and the end is covered by a rubber cap.
Q: Any suggestions short of me going systematically through Bert's checklist (once I find it...)?
Regards
Guy
This arvo...
Regards
Guy
