Number of posts : 7969
Well if you fix the connector issue on the gear selector switch it might read right so do that first.
BUT the only fix is swing arm out. Been there and lived 3 years with a bad switch......Even though guys repair them I simply replaced mine.
Just make sure clutch switch is good. Its tight but not sure is it a micro switch or not. The one on early Ks is a torpedo job and just unscrews out like a spark plug......if its like that screw in the new one BEFORE making the connections as the cable must turn as you screw it in.
1971 Yamaha 125 YAS-1
