1 Fueling Issue? Whats your best guess? Mon Dec 24, 2018 2:27 am
Bikelord
Hi again everyone!
A bit of a technical question for you all. I'm currently building a K100 cafe racer up from scratch using a m.unit and stripping all the unnecessary electronics out.
I'm really close to having the bike complete, but I'm currently running into an issue.
Currently the bike will only start and idle with the fuel pump disconnected.
I have tested the fuel pump, it pumps fuel in the correct direction and flows fuel through the front of the rail towards the back of the rail, through the FPR and then back into the tank. The injectors all seem to be functional all squirting as they should, spark plugs are all working sparking as they should, and compression is normal.
I've checked the alternator and it is charging the bike at 13.7 volts when it is idling.
When the bike has the fuel pump connected and you attempt to start the bike it will continue to crank and will struggle to start. as soon as you disconnect the pump the bike will fire up instantly, and idle normally.
I then went and tested the system by plugging the pump into a external power supply, and as soon as I connected the pump with the bike idling, the bike instantly chugged and shut down. Similarly when the bike is idling and the pump is plugged into the bikes connector, the bike will instantly start chugging and shut down.
So the question is, why would the bike be only able to start and run with the fuel pump disconnected? Could the issue be with the Fuel Pressure Regulator or something else I'm overlooking?
On the odd occasion that I have been able to get the bike to run with the fuel pump connected, it will only run briefly and very roughly, any advice would be greatly appreciated!
Cheers!!
Cheers!!
BMW K100RT 1987
BMW K100rt 1987 White Ex-Police (CHiPs)
