1Back to top Go down   Valve shim calculation Empty Valve shim calculation Wed Oct 31, 2018 4:41 pm
BooG
BooG
Can someone who is smart (?) go over the calculation for measuring shim size to obtain correct clearances at the valves? I've read a lot of posts, and looked at vids, but apart from that bloke who says, "If they're loose....leave em the f+*k alone...", (and he doesn't really explain how you calculate a replacement shim size) I'm not sure about the actual maths of it.
Embarassed
2Back to top Go down   Valve shim calculation Empty Re: Valve shim calculation Wed Oct 31, 2018 5:07 pm
nobbylon
nobbylon
measure the actual clearance.
If too large subtract required clearance from your measurement and add that to the thickness of your already installed shim to give new shim thickness required.
If too small, subtract your measured clearance from required clearance and subtract that amount from installed shim to give required shim thickness.
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
3Back to top Go down   Valve shim calculation Empty Re: Valve shim calculation Fri Nov 02, 2018 11:26 am
Here is a excellent Excel spreadsheet which automatically calculate the thickness of the shims needed.
You have to enter the current thickness of the shim, and the gap between the shim and the camshaft.
There is even a list of part numbers for new shims.
http://forum.kforum-tech.com/members-upload/uploads/Valves-adjustment.xls
Valve shim calculation Frog15Valve shim calculation Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
4Back to top Go down   Valve shim calculation Empty shims spreadsheet Fri Nov 02, 2018 11:38 am
brickrider2
brickrider2
Hummm.  I can't make that link work.
Oops. My bad.  I've got it now.  Nice piece of work for those of us who like to do our own wrenching whenever possible.  Thanks!
1996 K1100LT
5Back to top Go down   Valve shim calculation Empty Re: Valve shim calculation Fri Nov 02, 2018 11:47 am
brickrider2 wrote:Hummm.  I can't make that link work.
It works, but you have to download the file on your computer.
Then, you have to have Excel installed on your computer.
If you don't, you can download a free viewer. You will be able to enter your measurements but you cannot save the changes.
https://xlsx-viewer.en.softonic.com/?ex=DSK-1052.1
