1Back to top Go down   left hand switch K 100 Lt Empty left hand switch K 100 Lt Thu Oct 04, 2018 8:23 pm
wsiddins
wsiddins
would anyone have a detailed diagram of procedure.Used to have one but can't remember
where I got it. Cheers, Wes.
2Back to top Go down   left hand switch K 100 Lt Empty Re: left hand switch K 100 Lt Fri Oct 05, 2018 1:12 am
What procedure are you after, mate?
3Back to top Go down   left hand switch K 100 Lt Empty left hand switch K 100 Lt Fri Oct 05, 2018 3:26 am
wsiddins
wsiddins
A detailed diagram or photo mate.
4Back to top Go down   left hand switch K 100 Lt Empty Re: left hand switch K 100 Lt Fri Oct 05, 2018 3:33 am
A quick ask of the Google Gods produced a bit of detail from this very forum:
https://www.k100-forum.com/t174-headlamp-switch-repair
It's a start.
5Back to top Go down   left hand switch K 100 Lt Empty Re: left hand switch K 100 Lt Fri Oct 05, 2018 4:20 am
nobbylon
nobbylon
If it’s the low beam then dismantle the switch and on the contact block,
unsolder the worn out pin.
grind of the end of the pin the wire connects to and push through the plastic body.
make a new pin from a brass screw that is a tight fit in the plastic body.
solder the wire back on and jb weld that end to the plastic.
re assemble the switch.
tip, take apart in a large plastic bag to avoid losing parts.
Solder the new pin to the wire BEFORE pushing into the block.
left hand switch K 100 Lt 63943010
burnt out pin bottom left
left hand switch K 100 Lt F2e97210
new home made pin
left hand switch K 100 Lt 0961cb10
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
6Back to top Go down   left hand switch K 100 Lt Empty Re: left hand switch K 100 Lt Fri Oct 05, 2018 4:22 am
nobbylon
nobbylon
left hand switch K 100 Lt 932f6810
left hand switch K 100 Lt 6ff7aa10
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
7Back to top Go down   left hand switch K 100 Lt Empty left hand switch K 100 Lt Fri Oct 05, 2018 4:44 am
wsiddins
wsiddins
Have looked at that earlier on mate, thanks for your help.
8Back to top Go down   left hand switch K 100 Lt Empty Re: left hand switch K 100 Lt Fri Oct 05, 2018 5:04 am
keep in mind ...that with arcing from poorly connected pins to switch plate can also be an issue
left hand switch K 100 Lt Contac10
just something to be aware of
good luck
9Back to top Go down   left hand switch K 100 Lt Empty left hand switch K 100 Lt Fri Oct 05, 2018 7:28 pm
wsiddins
wsiddins
thanks fellas, all I'm doing is replacing Hi Lo switch as mine is past it, from photo you will see I've
already repaired it http://forum.kforum-tech.com/members-upload/uploads/sw7.pdfonce.
