Blackthumb
Blackthumb
Hi there everyone, I have a 1986 k100rt and am looking for campatible donor bikes (eccept the obvious.. 1986 k100rt). Thought this might be an interesting and helpful topic for everyone and their builds.
Bimmer officionados assemblllllllle! 👨‍🎤
Bimmers are cars.
Blackthumb
Blackthumb
My apologies Laitch....🙄
Flying brick officianados assemblllllllle!
Mid 1985 the Ks changed. They all look the same but are not. The 1983 to 1985 models have different fuel tanks, seats, panels, footpegs as well as some internal bits such as seals and shafts in the oil/water pump.
Good luck.
Blackthumb
Blackthumb
Thanks Stan, I thought that might be the case. I wonder if different models of the same year are interchangeable maybe? 🧐
I use www.realoem.com/bmw a lot for parts research. Search your particular motorbike, click on the blue highlighted part number, and up will come which other bikes that part number fits. It's best to drill down into each catalogue to verify it suits your needs. Often the supersession chain can be drilled down further for compatibility.
