MikeisonTV
MikeisonTV
Oil Drip from a rubber boot under the bike E4117010
I’ve got an Oil Drip from a rubber boot under my 91 k100. Anyone know what it’s called and if I need to replace the boot or if it means a seal underneath it is gone too?
The boot is torn, its clamp is loose or both.
From the MAX BMW parts fiche:
Oil Drip from a rubber boot under the bike Screen15
Oil Drip from a rubber boot under the bike Screen16
MikeisonTV
MikeisonTV
Awesome. Is there any procedural things I should know or remove and replace if torn kind of thing?
nobbylon
nobbylon
Motorworks and Motobins both have these boots at £15
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
yeah be careful installing it ...its far too easy to rip the boot again whilst the clutch arm is swinging free and the pressure of the internal spring is pushing the boot outwards , if you have already tightened the boot to the gearbox
sometimes it easier to fit the gland at the clutch arm ….then fit the boot to the gearbox ….after the clutch cable has been fitted and the clutch arm movement is restricted already
hope that helps
As Charlie says. Access is severely restricted and you need three hands to do the job. If you can find an excuse to pull the swingarm off then that's by far the easiest way to do it. What I do is to attach the boot to the clutch arm and then attach the clutch cable to the arm. This gives you some help when trying to compress the big spring and slide the pivot back in. After that, clamping the boot to the gearbox is (relatively) easy.
Laitch wrote:The boot is torn, its clamp is loose or both.
 A third reason.... The centre seal is just worn out. I replaced the one on my k1 last week for this reason. Which bike have you? It is impossible to do a 16v without removing the exhaust as the expansion box gets in the way of dropping the actuation arm far enough.
When fitting the new boot apply grease, petroleum jelly or silicone spray to the inside edges of the new boot and attach the arm end first, when you push the arm up the big open end usually slides into position without too much hassle.
Oil Drip from a rubber boot under the bike Ir-log1188....May contain nuts!Oil Drip from a rubber boot under the bike Ir-log11
K75RTP - 1994
Also, if its a 16v get new exhaust mount rubbers for it. The 16v exhaust can crack and this reduces the risk.
Chances are you will also need some nuts and studs and I never go near an exhaust on an unknown bike without having new washers studs and nuts to hand. The washers should be renewed.
Sometimes the rubber boot fills with oil over time and when the clutch is operated the oil squirts out. My solo does this and I just loosen the boot, clean out the oil and it's good for another couple of years.
