1Back to top Go down   Spark plug high tension leads Empty Spark plug high tension leads Sun Jul 15, 2018 11:02 am
nods
nods
Hi guys,
Do these leads 'wear out'/break down over time?  Or can I measure their resistance to test somehow?
Just wondering if I'll need to replace the originals on my bike.
Cheers,
Nods
Chassis number0025951
Vehicle code0504
ModelK 100 RT 84 (0504 ( 0505 )
Body typeK 100 RT 84 (0504
Production date1985 / 01
Engine0514)
Transmission
Steering
CatalyzerNONE
2Back to top Go down   Spark plug high tension leads Empty Re: Spark plug high tension leads Sun Jul 15, 2018 12:49 pm
Search brought up this page: https://www.k100-forum.com/t589-spark-plugs-and-ignition-wires
If the wires aren't giving you problems at the moment, don't fix them.
3Back to top Go down   Spark plug high tension leads Empty Re: Spark plug high tension leads Sun Jul 15, 2018 6:52 pm
My Brick has been fitted with NGK resistor caps and leads for the last twenty years. A mate's auto electrician son  got another two sets about 10 years ago for I believe $70.00 a set. I have a set as spare, but never needed so far.
Heed the warnings on fitting non resistor caps leads and plugs. I had a local ex BM tech tell me I should also run resistor plugs in conjunction with resistor leads. I gave it a go for one set and it didn't make any difference in the bikes running or in the colour of the plugs. So I am back on non resistor NGK plugs.  Rob may help with why he suggested this approach.
There are two types of NGK caps applicable to the Brick a 90 deg and a 45 deg angle. In OZ I can't run Bosch plugs due to the fact that they are not available with the screw off end caps, which NGK leads require. I've had no problems with NGK plugs.
Regards Martin
4Back to top Go down   Spark plug high tension leads Empty Re: Spark plug high tension leads Sun Jul 15, 2018 7:02 pm
I just thought I would add this. A mate with four bricks has had trouble removing OEM leads. The metal caps had corroded onto the spark plugs and the plugs and caps were destroyed on removal. Has this been a problem for any other inmates.
5Back to top Go down   Spark plug high tension leads Empty Re: Spark plug high tension leads Sun Jul 15, 2018 7:05 pm
nods
nods
Thanks a lot Rob and Martin 👍
Sent from Topic'it App
Vehicle code0504
Engine0514)
Transmission
Steering
CatalyzerNONE
6Back to top Go down   Spark plug high tension leads Empty Re: Spark plug high tension leads Sun Jul 15, 2018 7:44 pm
MartinW wrote:... Rob may help with why he suggested this approach.
Sorry Martin. I didn't make any suggestions. I pointed nods to an existing page on K100-forum with answers to his question. I wouldn't recommend running resistor-caps and resistor-plugs either.
MartinW wrote: Has this been a problem for any other inmates.
I've never encountered corroded caps or difficulty removing/installing them on any of the Bricks I've owned or helped with.
7Back to top Go down   Spark plug high tension leads Empty Re: Spark plug high tension leads Sun Jul 15, 2018 7:46 pm
Isn't there a recommended resistance range where the K100 plug leads are still good?
8Back to top Go down   Spark plug high tension leads Empty Re: Spark plug high tension leads Sun Jul 15, 2018 7:59 pm
Thanks Rob on two of the mates plugs the only way he was able to get the leads off was to actually break the porcelain on the plugs. I don't think was able to ever get the remains of the plug out of the cap. The bike was running but the caps were badly corroded.
