1 Engine misfiring when warm Tue Jun 18, 2013 3:02 am
Rabidchiwawa007
Hello everyone,
This is in regards to a 1992 K100RS. There are 100k miles on the bike, but only about 31k miles on the engine. Everything is fine and dandy when the bike is cold, but once it warms up, the engine starts to misfire. It's nothing that keeps it from being rideable, but it does cause noticeable drops in power when it occurs. It misfires both when revved in neutral and while in gear / moving. The misfiring goes away at about 4k rpm and up. The issue has been worsening noticeably over the past couple weeks.
Things that are known-good:
-valve clearances were done by a BMW shop ~2k miles ago.
-all rubber parts that could cause and air leak are brand new (2-3k miles). This includes the plastic boot with the O-rings underneath the TBs
-Air filter is brand new
-Just replaced some wires with melted insulation that went to the starter relay, and some of the wires around them (replaced the starter relay as well)
-Spark plugs are brand new (2-3k miles), I also recently cleaned them which helped this issue a little bit but did not solve it.
Things I am thinking:
-Is it possible this type of thing could be caused by a loose timing chain?
-I read around the forum a little bit on plug leads as a culprit, but that was mainly when under load from what I read. I assume this is still a possibility, and I think the ones on this bike are original, but not sure.
-Possibly something to do with the coils? Connections? Cracked coil casings causing them to arc?
-Fuel pressure regulator? When I got the bike back from the shop, the mechanic told me that the FPR gave a wacky vacuum reading at idle and low RPMs, but that once he got the bike out on the road and up to speed that it evened out. The fact that he said idle and low RPM (the range my issue is in) makes me think of this as the most likely culprit. I should buy a new one either way, but money's just that tight right now.
What gets me is that it's normal when it's cold and only starts to misfire once it warms up. Seems backwards to me.
Thanks in advance!!
Thanks in advance!!
1968 BSA Lightning
