1 ABS Non-Starting Issue Fri Jul 06, 2018 8:10 am
markysimon
The almost new battery on my 1991 K75S wwent flat due to my inadvertently leaving the ignition on. I re-charged it, switched on the ignition and the ABS warning light and hazard lights flashed but the starter wouldn't turn (although the fuel pump did it thing). After 24– 25 seconds everything stopped flashing, but it still wouldn't start and when I then turned the ignition off and on, it all started over again.
I tried re-setting the ABS several times using the trick suggested on the forum (grounded wire in the central terminal of the diagnostic socket), but that didn't work, so I'm at a loss and very frustrated that I can't go riding in this lovely weather – any suggestions short of removing the ABS altogether which I'm loathe to do?
(BTW, the bike was fitted with an aftermarket anti-theft system which has caused problems in the past, but which I partially disconnected).
