1Back to top Go down   Fuel pump wires Empty Fuel pump wires Fri Jul 13, 2018 8:18 am
quick one kids. I just swapped tanks and had to refit the old pump to the new tank. Anyhow have two wires one brown one grey. I assume brown is earth but bmw does funny stuff like changing wire colours halfway through looms.
Cheers klompy
KKlompy Fuel pump wires 2854237993
Fuel pump wires Au-log10
2Back to top Go down   Fuel pump wires Empty Re: Fuel pump wires Fri Jul 13, 2018 9:33 am
I think the position stays the same regardless of the colours klompy
ive seen a few different tank to connector... to mine but the same connection location standard
unless someone has seen different ...best I can offer
3Back to top Go down   Fuel pump wires Empty Re: Fuel pump wires Fri Jul 13, 2018 9:35 am
So brown is earth then yes? Thanks Charlie assumed the pump would suck if wired backwards. Lol
4Back to top Go down   Fuel pump wires Empty Re: Fuel pump wires Fri Jul 13, 2018 10:15 am
Test it to be sure.  Ohmmeter between brown inside the tank and brown on the 4-pin connector.  If you get continuity, then great.  Try the same for your Grey wire inside the tank and the Green/White on the 4-pin connector.
5Back to top Go down   Fuel pump wires Empty Re: Fuel pump wires Fri Jul 13, 2018 10:17 am
good advice rob
its what I would do
6Back to top Go down   Fuel pump wires Empty Re: Fuel pump wires Sat Jul 14, 2018 11:41 pm
Good morning all;
Good news the new tank with old pump new filter new hose is fitted and working great. As feedback the colours of the wires is Not important as the terminals are different sizes. How did I not notice that so boys and girls I found something fool proof in a K!!!
Anyhow this dispels the rumor that all things brown are earth.
Fuel pump wires 7c6d3610[url=https://servimg.com/view/19539246/76]Fuel pump wires 7c6d3610[/url]
7Back to top Go down   Fuel pump wires Empty Re: Fuel pump wires Sun Jul 15, 2018 5:37 am
good to hear that its on the road klompy
