1 K100 collector Sat Sep 27, 2014 3:43 am
Mossy1200
Ok spent the day with Malcolm
Have the mild steel prototype unit with oversized inlet pipe to check angles. Some modifications on the cluster of the inlets to better suit the pipes natural layout so it wont be the stock standard square pattern of most collectors but closer to the natural pipe layout of a k100.
He is happy to take orders for anyone who would like one.
Note the outlet length on the stock unit will be 40mm longer for those who like short pipes and you will need cut it down to suit if you want it shorter or advise Malcolm.
Prices are very good.
Stainless with outlet pipe to suit 54mm ID(note you can pick another size but it will add some cost as these will be hand made items).
Remember its a hand made item so any additional requirements can be arranged. Perhaps spring hoops and so on.
$160 NZD plus freight.
This is approx. 140USD or AU dollars plus freight or 85 UK Pounds.
Contact details
malcdel@xtra.co.nz
Please include K100 collector as a Title as xtra emails tend to spam out untitled emails easily.
Note added this here.
This is only a mild steel trial.
Seem in collector will be at the back.
Headers require cut 2inches forward of the gear change shaft.
Will post a finished product photo when complete and mounted.
Contact details
malcdel@xtra.co.nz
