1Back to top Go down   Belly pan Empty Belly pan Sat May 12, 2018 1:29 pm
K100 RS
K100RS with 1100 motor Premier sidecar
K100 RT KRAUSER FAIRING
R1200GS
650 Vstrom
2Back to top Go down   Belly pan Empty Re: Belly pan Sat May 12, 2018 1:59 pm
For the 16V models, but fits also 8V's...homemade mounting bracket.
3Back to top Go down   Belly pan Empty Belly Pan Sun May 20, 2018 1:35 pm
markysimon
markysimon
Slotting the belly pan (on my K75S) into the two rubber grommets at the front end, is incredibly tricky, and after tightening up the bolts once you *think* it's in place, it still wobbles around a bit.  Shocked Is there an easy, failsafe way to do this as I'm slightly afraid of it coming lose... at 90mph  Twisted Evil
4Back to top Go down   Belly pan Empty Re: Belly pan Sun May 20, 2018 2:49 pm
Inge K. wrote:For the 16V models, but fits also 8V's...homemade mounting bracket.
Yes, the 2V and 4V BPs are slightly different but can be made to interchange with some DIY effort.
5Back to top Go down   Belly pan Empty Re: Belly pan Sun May 20, 2018 2:54 pm
markysimon wrote:Slotting the belly pan (on my K75S) into the two rubber grommets at the front end, is incredibly tricky, and after tightening up the bolts once you *think* it's in place, it still wobbles around a bit.  Shocked Is there an easy, failsafe way to do this as I'm slightly afraid of it coming lose... at 90mph  Twisted Evil
I've owned something like half a dozen K75Ss and as long as you get those two long M6 bolts properly threaded and fairly tight then it won't fall off.  And at 90 MPH there's lots of wind pushing on the front of it to keep it on the mounting brackets.
6Back to top Go down   Belly pan Empty Re: Belly pan Sun May 20, 2018 3:04 pm
markysimon
markysimon
Good point: I'll just have to ride everywhere at 90mph !  Wink And I guess there is no easy way to slot it into the grommets...?
7Back to top Go down   Belly pan Empty Re: Belly pan Sun May 20, 2018 3:47 pm
It's a bit tricky. No way around that.
I wasn't satisfied with how hard it is to do on a K75 so I decided to mount a K75 belly pan on a K100. That one's even harder to get mounted on those grommets and I had to drill new holes in the BP in just the right places to get them to line up to where that lower front bracket gets mounted on the longer engine.
Belly pan 13_k100u
8Back to top Go down   Belly pan Empty BP for 1986 K100RS Fri Jul 13, 2018 4:33 pm
mappedFA
mappedFA
Hello all - I am looking to fit a belly pan for my 1986 K100RS. I know that the belly pan wasn't introduced until later models -
* Can a belly pan be fitted to a 1986 K100RS?
* Any advice/tips on what to look for when looking for them on eBay?
Many thanks!
9Back to top Go down   Belly pan Empty Re: Belly pan Fri Jul 13, 2018 4:37 pm
mappedFA wrote:Hello all - I am looking to fit a belly pan for my 1986 K100RS. I know that the belly pan wasn't introduced until later models -
Many thanks!
Yes. But get the one for the 2V RS, not the 4V RS. They look very similar but are slightly different and mount differently.
Find one with both the mounting bracket and BP if you can.
10Back to top Go down   Belly pan Empty Re: Belly pan Fri Jul 13, 2018 4:55 pm
BobT
BobT
I have a 16v one with the mounting brackets for sale if anyone needs one.
11Back to top Go down   Belly pan Empty BP for 1986 K100RS Fri Jul 13, 2018 7:01 pm
mappedFA
mappedFA
BobT wrote:I have a 16v one with the mounting brackets for sale if anyone needs one.
Hi BobT - what colour is your Belly Pan? How much are you looking for it?
12Back to top Go down   Belly pan Empty Re: Belly pan Fri Jul 13, 2018 7:02 pm
mappedFA
mappedFA
Many thanks!
Hi - thanks for the feedback and advice!
13Back to top Go down   Belly pan Empty Re: Belly pan Fri Jul 13, 2018 7:17 pm
BobT
BobT
It is black, and want about £70 plus P&P, which will cost a fortune due to the weight of the thing.
14Back to top Go down   Belly pan Empty Re: Belly pan Fri Jul 13, 2018 7:30 pm
mappedFA
mappedFA
Hi - could you send me some pictures of it? I would like to see it if possible - I am based in the UK, would you be able to post it here if a sale was agreed?
15Back to top Go down   Belly pan Empty Re: Belly pan Fri Jul 13, 2018 9:33 pm
BobT
BobT
I could post it there with no problems. I will be in the UK on the 8th of August for a tour around Devon and Cornwall, but will be on my Ducati Supersport 939, and that has no room for much in the way of luggage.
I'll take some pictures over the weekend.
16Back to top Go down   Belly pan Empty Re: Belly pan Fri Jul 13, 2018 10:06 pm
mappedFA
mappedFA
BobT wrote:I could post it there with no problems. I will be in the UK on the 8th of August for a tour around Devon and Cornwall, but will be on my Ducati Supersport 939, and that has no room for much in the way of luggage.
Okay - brilliant stuff - thank you
17Back to top Go down   Belly pan Empty Re: Belly pan Sat Jul 14, 2018 8:06 pm
mappedFA
mappedFA
hBobT wrote:I could post it there with no problems. I will be in the UK on the 8th of August for a tour around Devon and Cornwall, but will be on my Ducati Supersport 939, and that has no room for much in the way of luggage.
Hey - hope you're having a good weekend! How are the pictures coming along? (sorry to chase) - where are you based by the way, trying to figure postage costs!  Very Happy
18Back to top Go down   Belly pan Empty Re: Belly pan Sat Jul 14, 2018 8:16 pm
BobT
BobT
South of France mate, if you can figure out the postage costs then let me know. I shall have to weigh the pan and mountings, get rough dimensions and then ask at the post office which will be funny.
You could join the Irish contingent and visit in September and fit it here, talk to Olaf and he will give you the dates.
I'll do the pictures tomorrow afternoon.
19Back to top Go down   Belly pan Empty Re: Belly pan Sun Jul 15, 2018 8:16 pm
mappedFA
mappedFA
Hey BobT - hope you've had a great weekend. I not sure what the costs would be for postage, but recently purchased full K100 panniers from Germany (via eBay) and it was around the £20 mark. I am sure we can figure that out! Any joy with the pictures?
Many thanks!
20Back to top Go down   Belly pan Empty Re: Belly pan Tue Jul 17, 2018 1:53 pm
mappedFA
mappedFA
Many thanks!
Hey - hope your week is going well - any updates on that BP? Thank you again!
21Back to top Go down   Belly pan Empty Re: Belly pan Thu Jul 19, 2018 3:33 pm
Ian T
Ian T
avataron Sun May 20, 2018 2:47 pm
by duck
Love the bike what sort of paint have you used
22Back to top Go down   Belly pan Empty Re: Belly pan Thu Jul 19, 2018 5:43 pm
Ian T wrote:Love the bike what sort of paint have you used
It's not actually paint, it's Line-X truck bed liner. I use it because it's inexpensive and incredibly durable compared to paint.
Note that you can buy truck bed liner in a rattle spray can at the auto parts store but I've tried it and it doesn't hold up like "real" truck bed liner. The reason is that stuff like Line-X is actually a two part material similar to epoxy so when applied it doesn't dry, it actually cures. The Line-X shops have special two nozzle sprayers that mix the two parts as it's applied.
Back on the issue of belly pans: On the K75S I've been playing with lately I discovered that it's much easier to get the K75 BP properly mounted if the fairing radiator panel is removed so it doesn't get in the way of the top front of the belly pan. It seems like extra work to remove and then have to reinstall the radiator panel but IMO it's worth it because it makes getting the BP on properly fitted so much easier.
