1Back to top Go down   Belly pan repairs Empty Belly pan repairs Mon Apr 10, 2017 4:48 am
KiwiK100
KiwiK100
Hi all,
I have purchased a belly pan and all mounting hardware for my 4V however there is some damage that needs filling. The item is stamped BMW and also pfeba on the inside. The belly pan is quite flexible and about 6mm thick. Under the paint the composition is very pale yellow and when heated, very soft. Any idea what the material is, and what do you suggest to repair any damage with. Would flexible plastic putty work?
Thanks for your help
Current rides:
2020 R1250RS. Metallic black with all the fruit
1983 K100C. Red. Krauzer fairing.
1984 K100RS. Madison silver.
2002 K1200RS. Owned from new. Pacific Blue, Ohlins, Speiglers, Fiamms, HID. 186,000km SOLD Crying or Very sad
1991 K1. Schwartz metallic black, 18 month frame off restoration. 74,000km SOLD Crying or Very sad
1987 K100RS Style. Black, Ohlins, Race Tech springs, Braided lines. Fully restored. 53,000 miles. SOLD Crying or Very sad
The family history:
1951 AJS 500 single - my Dads ride
1953 Triumph Terrier - my Mum's ride
1916 Triumph Type H, Battle of the Somme, France WW1 - my Grandads ride
2Back to top Go down   Belly pan repairs Empty Re: Belly pan repairs Mon Apr 10, 2017 10:52 am
The normal fibreglass matting and epoxy is the stuff to use. My RT fairing had 3 broken mounts where the antlers attach. I had to rebuild those with epoxy resin putty and then reinforced around them with fibreglass. I also had a major crack around the r/h mirror which the PO had covered over with bog.
Three or four layers of fibreglass on the inside and filled the crack outside with epoxy putty. Don't rush it. Let the resin cure slowly. It will be much stronger.
 Belly pan repairs Austra12    Fuel:  95 Octane
3Back to top Go down   Belly pan repairs Empty Re: Belly pan repairs Mon Apr 10, 2017 12:39 pm
KiwiK100 wrote:Any idea what the material is,
High pressure molded polyurethan foam.
4Back to top Go down   Belly pan repairs Empty Re: Belly pan repairs Mon Apr 10, 2017 1:25 pm
BobT
BobT
Holister wrote:The normal fibreglass matting and epoxy is the stuff to use. My RT fairing had 3 broken mounts where the antlers attach. I had to rebuild those with epoxy resin putty and then reinforced around them with fibreglass. I also had a major crack around the r/h mirror which the PO had covered over with bog.
The fairing is solid and fiberglass is fine, the belly pan is very flexible, I assume to withstand stone chips.
I have a spare 16v belly pan and mounting in my garage, but fear that postage would be prohibitive if anyone wanted it.
5Back to top Go down   Belly pan repairs Empty Re: Belly pan repairs Mon Apr 10, 2017 2:40 pm
KiwiK100
KiwiK100
Inge, thank you very much for your concise answer! Prefect.
Current rides:
The family history:
