1 Proper voltage during running Thu Apr 05, 2018 9:29 am
George_Pap
Hi all, recently changed my battery to a 30Ah (690CCA) battery.
Not ridden my bike since the swap due to servicing in my backyard.
Every day though i'm starting the motor once and leave it running for 10 minutes
Facing problems with the fuel pump and some grounding connection with the clock and GPI switch not working.
So in my K100 RT's voltage meter ( double checked with a hadheld voltage meter) with the bike on the center stand and idle to 2000 rpm the reading i was getting was about 13.5V to 14V
Today after a blown fuse (number 3 from top) and some issues with the instrument cluster i took it off to check it.
After that i started the bike again and i was getting 12.2 . - 12.5V on the bikes voltage meter and cross-checked with my voltage meter by measuring directly on the battery poles the same numbers.
Isnt 12.5V while the engine running at 2000 rpm very low? Before starting the engine i measure 13,5V on the battery..
Is this a new problem i have to face??
Thank you
Thank you
K100RT (Early 1985 -nonABS)
