1Back to top Go down   1984 K100 headlight connector Empty 1984 K100 headlight connector Tue Apr 17, 2018 9:38 pm
EnJCoop
EnJCoop
Hi All,
This is a little but annoying thing...
Headlight connector: can the wires be removed easily from this? I can remove one but not the other two and it mildly frustrating...
1984 K100 headlight connector Img_0510
https://i.servimg.com/u/f62/19/89/64/73/img_0510.jpg
What hope is there for my project if I am stumped by this? Ugh...
2Back to top Go down   1984 K100 headlight connector Empty Re: 1984 K100 headlight connector Tue Apr 17, 2018 9:43 pm
3Back to top Go down   1984 K100 headlight connector Empty Thanks!! Tue Apr 17, 2018 9:54 pm
EnJCoop
EnJCoop
4Back to top Go down   1984 K100 headlight connector Empty Re: 1984 K100 headlight connector Tue Apr 17, 2018 10:12 pm
It always stumps me how manufacturers like BMW and others can put so much time and research into making what is a damn good bike and then stuff up something as simple as that by not having a relay. 1984 K100 headlight connector 610153
5Back to top Go down   1984 K100 headlight connector Empty Re: 1984 K100 headlight connector Tue Apr 17, 2018 10:13 pm
I keep a couple of 'electrical' screwdrivers with the ends ground down and reshaped specifically for flattening tangs on terminals.
Rick: ditto using the frame as the main earthing point instead of just picking it up 'in case'. IMDNSHO the only way to correctly design a wiring loom is to include a full earth return.
6Back to top Go down   1984 K100 headlight connector Empty Re: 1984 K100 headlight connector Wed Apr 18, 2018 2:41 am
My .02:
Add relays and beef up the wiring. Use a ceramic H4 connector.
Once the wiring is beefed up I use 100/90 cheapo "Xenon" H4 bulbs from Fleabay.  Great bang for the buck.  (Don't use this wattage on stock headlight wiring.)
Adding relays:
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/hl.relays/hl.relays.htm
7Back to top Go down   1984 K100 headlight connector Empty Re: 1984 K100 headlight connector Wed Apr 18, 2018 2:57 am
BobT
BobT
Never had a problem with that connector, the only people who do are people who fit higher wattage headlight bulbs that give 15% more light for twice as much power and twice as much heat. They also go over the legal 60 watt limit for headlight in the UK and Europe and I would expect most other countries.
8Back to top Go down   1984 K100 headlight connector Empty Re: 1984 K100 headlight connector Wed Apr 18, 2018 3:45 am
Yeah, 100W is technically illegal but I've been running them in all of my Ks for well over a decade and have never had any issues with cops.  But they put out a TON of light and I can comfortably do 80+ MPH at night without outrunning my high beam.
All the cops care about (at least in the US) is illegal HID kits. (I do run those in my driving lights but wouldn't HID kit a headlight due to the stray lighting from a headlight system not designed for HID.)
Never had any heat issues running the higher watt bulbs.  Not even with plastic H4 connectors but I do use ceramic ones now just to be on the safe side.
9Back to top Go down   1984 K100 headlight connector Empty Re: 1984 K100 headlight connector Wed Apr 18, 2018 5:15 am
Avenger GT
Avenger GT
duck wrote:Yeah, 100W is technically illegal but I've been running them in all of my Ks for well over a decade and have never had any issues with cops.  But they put out a TON of light and I can comfortably do 80+ MPH at night without outrunning my high beam.
the speed of light =
299 792 458 m / s.
You would be fairly moving to outrun that Duck!!   Cool
10Back to top Go down   1984 K100 headlight connector Empty Re: 1984 K100 headlight connector Wed Apr 18, 2018 6:45 am
299 792 458 m / s.
Eats tires pretty quickly too! affraid
