1 Left turn signal lights stuck on Sat Feb 24, 2018 2:21 pm
timz10000
My left turn signals are stuck on, even when I turn off ignition and remove key. (The dash left turn signal green light is stuck on too even when key is removed, no blinks).
Did I blow out a turn signal relay? Or other? Any ideas?
A series of events led to this described below.
- I replaced the turn signals with aftermarket ones and they were working fine.
- I just cleaned out the left handlebar switch unit to fix a headlight issue (dead spot between low and high beams). After that the turn signals still worked fine.
- This morning I knocked into the left rear turn signal and it broke off the stem. That's when the problem started. I cut one wire to the rear and to the front turn signal to get them to turn off, but the dash left turn light still stays on
1985 K100
