I'm moving over from the renovation part of this forum to the sidecar part as we start building now!
I'm drawing som 3D on my spare time so the general idea is coming along nicely:
__________________________________________________ Leikarnes MC Rebuilding, custom work 1984 - BMW K100RT under long time rebuilding to K100GS 1984 - BMW K100RS with 1998 K1100 engine under building to single sided front suspension and sidecar. 1990 - Suzuki DR750 Big 1990 - Suzuki GS500E Cafe Racer 2011 - Triumph Tiger 1050 2003 - Honda Varadero XL 125 Street fighter My Norwegian blog translated to english
Design looks good now, you need a good 3D printer to do the hard work
__________________________________________________ "Man sacrifices his health in order to make money. Then he sacrifices money to recuperate his health. And then he is so anxious about the future that he does not enjoy the present; the result being that he does not live in the present or the future; he lives as if he is never going to die, and then dies having never really lived." Dalai Lama
We've started welding up the single sided front suspension mount now;
Mockup
New saddle on the K1100! The old one was too high to ride the bike comfortable... Going to fit GSXR750 clipons soon too!
I'm curious to see how this turns out, as I love to see experimental and creative suspension concepts turn to reality, and also wondering what sort of Norge governmental inspection it'll have to be put through to be considered 'roadworthy'.
Two Wheels Better wrote:I'm curious to see how this turns out, as I love to see experimental and creative suspension concepts turn to reality, and also wondering what sort of Norge governmental inspection it'll have to be put through to be considered 'roadworthy'.
Govermental inspection yes... we do not plan to ask them to do one... the bike already has a license plate... Until last year all rebuilding was banned totally in the legal way... But as the frame we are using is a veteran this year, we can get it registered as a vetran in the condition it is when reviewed for getting veteran papers. Veteran is when the bike is over 30 years old in Norway, it's much cheaper to own and use! This is our third suspension build like this one, The designs are getting more and more radical! Got one more in our heads, Bimota lookalike, one control arm on each side of a car hub of a Smart car.
The front and rear wheels on this one too is going too be from a Smart car, if we just could get ahold of some...
New rims for the build ordered! I'm hopefully going to get them from the supplier today! Genius Darwin Gunmetal rims for a Smart Car.
More welding and fabrication pic's! We do not have an advanced drilling machine:
My dad TIG-welding the frame for the swingarm on the bike.
Tight fit:
Test fitting on the bike:
BMW car bushings for the swingarm mounts:
My dad was not satisfied with the saddle, so a new one was made:
With heat!
Templates for the combined engine/swingarm mounts:
The result!
Double steel thickness at the top mounts:
The engine frame mount for the swingarm is done! Close one though, the Argon bottle is empty...
Sidecar mount:
__________________________________________________ VIN 0191428, 1991 K100LT, formerly owned by Lancashire Constabulary. This old warhorse is now 'out to grass' and living in retirement in Suffolk, where it will be showered with appropriate love and care.
The sidecar is going to be made out of strips of wood, fiberglass and epoxy, like we made theese kayak's some years ago!
Template for start of the wood building, in our wood shop: ¨
The crossover is where my knees are when sitting like we think we will...
It's going to be coated with fiberglass and epoxy, then smoothed out and painted red.
Bottom of the sidecar being produced in plywood this time:
Fiberglass and epoxy coating on the inside of the sidecar:
Starting to build the frame inside the sidecar, all pipes are stainless steel.
Some mockup of the control arms on the old K100 engine:
Trying to get the right height:
General look test, before we start to fit it in correct
Turning out a new spacer for the rear wheel to fit the smart car wheel:
You can see the blueprint and drawings of how to turn it on the lathe on the side of the aluminium piece...
Lathe and cutter at dad's work place:
The new front end coming together nicely!
Cross to strengthen the construction and general fitment of the front wheel. The new front bearing mount is coming together too, but i do not have any pictures of that until tonight!
This will be enough turning action
Here is a picture my dad took of the K1100 on Crystal Rally this year:
1st May yesterday, it's a tradition to go on a motorbiktrip at 1st May here, but when i wake up I saw this from my window:
Some more front suspension build pictures:
One old GSXR shock will make do until we get a new one. The shock mount is moveable until we get it on all three wheels and we'll be able to drive it and figure out where to put the shock.
Steering and control arm done, now it's just the tie rods up to the lower fork bridges left! Gotta turn out some new aluminum rods to connect the two fork bridges too.
General setup, and the dog, Guzzi looking it all over!
Trying to figure out where to put the sidecar fork...
Mathematics and mechanic calculations at school can be transferred a bit into building too, trying to figure out which way it's best to mount the shock on the sidecar.
It's made at the crooked angle to accomodate the travel of the wheel due to the constant changing angle on the hub. The rods are going to be chaged to stainless BMW E46 318IS stabilisator rods when we get some in the mail in near future!
As always: great to see you're progress ! Hope there is a change of weather in your region, so that you can get out of the shed every once and a while ?
Cheers... Jos
__________________________________________________ Ich bin enge Kirchröatsjer jong; adieë wa ?! 1992 K1100LT 6458188 1987 K100LT (RS-fairing) 0170844 + sidecar EML GT2001 1986 K100RS 0085647 + sidecar Velorex 562 1985 K100RT 0027026
GTJos wrote:As always: great to see you're progress ! Hope there is a change of weather in your region, so that you can get out of the shed every once and a while ?
Cheers... Jos
My dad isn't that many days in the shed all things considered, I'm only home on the weekends, but it's mostly evenings that is spent in the garage!
Here's a video from now on sunday:
Some more pictures from earlier on in the build progress from my dads camera: Pictures from the progress making the hack:
Top half done, time for the bottom part!
Cheers... Jos
Ha ! A speedy ride in an astonishing scenery; still lots of snow I see ?! Thank's; keep up the good work ! (Great to see the 'boat' growing from nothing to its present state. Good craftmanship, that's for sure !)
Jos
We've started fiddeling with the K again! My dad has made a new swingarm, the last one was too short to get the suspension geometry right. There was no room to move the lower spring mount around to get more suspension travel.
The old swingarm and pipes for the new one.
New swingarm being mounting:
New and old swingarm, the new one looks more lean and is better made to accommodate better suspension
Ready for mounting of the hack!
Hack trial mounted!
Hack suspension:
I saw that i posted the reply in the wrong sidecar thread... so I'll repost it and build on some more pictures!
Making of a new fender on the sidecar, also in wood!
Cut down and epoxy'ed up!
A little sanding before a fast temporary paint job
Temporary paintjob done! There is going to be some white stripes to!
Some may remember Donald Duck's 313 car? this seat/lid is made the same way as his backseat!
Don Rosa and Carl Barks knows how to make inspiration for sidecars!
Some of my dads other inspiration is these Formula 1 cars: Ferrari 500 F2
Maserati 250F
Sidecar mounted once again!
New custom made brakelines from Venhill parts!
Close call with the rim!
Brake lines to the sidecar wheel, one caliper is hooked up to the front brake and one is hooked up to the rear brake.
Two times Kawasaki GPZ 750 rear calipers on the sidecar wheel.
Radiator and grille mounted, the fan is hooked up to the ignition.
Rear light on the sidecar mounted too, we need to find a white and orange LED light for the front...
Test ride!
Hit 1080p HD!
That's good. I've enjoyed reading this thread - there's some really interesting engineering going on there.
__________________________________________________ 1983 K100 naked upgraded to K100LT spec after spending time as an RS and an RT 1987 K100RT Others... 1978 Moto Guzzi 850-T3, 1979 Moto Guzzi 850-T3 California,1993 Moto Guzzi 1100ie California 2020 Royal Enfield Bullet 500
Impressive build and makes a very interesting read. Thanks for the posts. In the end what made you decide how and where to mount the shock on the sidecar? It looks to be pretty much vertical? Sean.
