1 Anyone have a picture of the instrument cluster connector? (PFA) Wed Sep 20, 2017 11:20 am
boostd4
Moving along with my streetfighter/cafe project. I have an Acewell instrument cluster I bought and am making plans to wire it up. In my research, it appears the Marulabs BEP 3.0 is my best bet as they state they worked with Acewell specifically to get speedo/RPM/fuel level inputs conditioned to work with factory wiring.
The hard part is I bought the bike without an instrument cluster. I'm not sure if the previous owner just cut the wiring/connector out (I assume it was supposed to run up above the triple tree where the cluster is - it's obviously not there now. I know from looking at the BEP 3.0 instructions that there should be two 12 pin single row connectors for the stock cluster.
If anyone has a picture of these connectors and where they run under the tank it would be extremely helpful.
Also, if they've been removed, does anyone know if these are part of a separate harness I can buy at the dealer? Or do the wires terminate in many different places?
A few pics:
As I got it:
Where I'm at now:
A few pics:
As I got it:
Where I'm at now:
